Krylon vs VHT wrinkle paint
Old Apr 16, 2007 | 06:00 PM
invisible's Avatar
Default Krylon vs VHT wrinkle paint
Yeah I messed up on the title ...I'm trying to find the closssset as possiable to OEM wrinkle for my valve cover. Post up your pictures and which brand you used, post specifics cuz I think there's more than one kind of wrinkle paint for each.
Old Apr 16, 2007 | 06:52 PM
invisible's Avatar
Default Re: Krylon vs VHT wrinkle paint (cheesee)
bump
Old Apr 16, 2007 | 08:42 PM
invisible's Avatar
Old Apr 16, 2007 | 10:45 PM
invisible's Avatar
no one?
Old Apr 19, 2007 | 06:46 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
You may try asking in this thread. I bet's it's been covered numerous times.
https://honda-tech.com/zerothread?id=1362165
Old Apr 19, 2007 | 07:11 PM
John M's Avatar
Default Re: Krylon vs VHT wrinkle paint (-NA-aLL-thE-wAy-)
Vht red wrinkle works great. I got the exact same look as the real type r valvecover
Old Apr 19, 2007 | 07:29 PM
invisible's Avatar
Default Re: Krylon vs VHT wrinkle paint (John M)
Wow didn't know this new forum was made
Any pictures?
Old Apr 19, 2007 | 10:38 PM
invisible's Avatar
hum i think this should be moved back into the appearance...
Old Apr 19, 2007 | 11:01 PM
John M's Avatar
Old Apr 19, 2007 | 11:43 PM
invisible's Avatar
any close ups?
Old Apr 20, 2007 | 07:10 PM
JokerX-1.6T's Avatar
All done with the krylon wrinkle and it holds up really well
heres the latest my d15 I did
some sand paper and a wood block to sand the logos back so they shine nice
and heres one when I just went crazy and tried to make the bay look decent after I picked up this crx - I did the cai and vavle cover
and y8 motor I had around I did
Modified by JokerX-1.6T at 11:21 PM 4/20/2007
Old Apr 20, 2007 | 07:45 PM
John M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheesee &raquo;</TD></TR><TR><TD CLASS="quote">any close ups? </TD></TR></TABLE>
Old Apr 21, 2007 | 06:29 AM
SHG_Riley's Avatar
Go with VHT
Old Apr 21, 2007 | 09:24 AM
invisible's Avatar
Default Re: Krylon vs VHT wrinkle paint (r7t1g8)
i couldn't remember which one i used before but it looked nothing like oem. looked like this (not mine btw tho)
Old Apr 21, 2007 | 03:16 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r7t1g8 &raquo;</TD></TR><TR><TD CLASS="quote">Go with VHT </TD></TR></TABLE>
Did they ever get there act together ? I remember a lot of distributors having issues with there faulty nozzles.
Old Apr 21, 2007 | 05:47 PM
EJ8tunerman's Avatar
Default Re: Krylon vs VHT wrinkle paint (RCautoworks)
I used Krylon Red Wrinkle paint on my valve cover and it came out flawless and has been that way for over a year.
Old Jul 4, 2007 | 05:43 AM
allstokhonda's Avatar
Default Re: Krylon vs VHT wrinkle paint (Brendon Small)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brendon Small &raquo;</TD></TR><TR><TD CLASS="quote">i couldn't remember which one i used before but it looked nothing like oem. looked like this (not mine btw tho)
I'm testing the krylon on a few parts right now, and it looks just like the pic above.
how long does it take for this stuff to cure. It's sat for about a day, but I'm sure it's gonna take longer to harden.
I'll most likely switch to the VHT. I like the looks of it bettter, but wanted to try the krylon just to see.
-Chad-
Old Jul 4, 2007 | 05:58 AM
Mr. Em1's Avatar
Default Re: Krylon vs VHT wrinkle paint (allstokhonda)
I havent had experience with both, but VHT Red Wrinkle paint worked great for me.
It is very important to follow the directions on the pain can, you need to do heavy coats in a short amount of time and you hgave to put it in the oven for an hour at about i think 250 degrees, the oven tightens up the wrinkles. Good luck to everyone who tries it!
Old Jul 4, 2007 | 08:20 AM
Genuine Rolla's Avatar
either or should be good.
Old Jul 4, 2007 | 10:11 AM
Well, i just finished my valve cover. I think it turned out pretty good. It's still gotta set a while, but I used a blow dryer between each coating and preheated the valve cover before the first coat. everything layed down good.
I'll be honest, I did screw up the first coat. So, I stripped the whole valve cover down, again. and redid it. I think I'm gettin the hang of it now.
here's a few pics.
Preped and ready for paint
Just freshly sprayed
-Chad-
Modified by allstokhonda at 3:25 PM 7/4/2007
Old Jul 9, 2007 | 09:38 PM
Obama's Avatar
Default Re: (allstokhonda)
bump for more pics trying to decide
Old Jul 10, 2007 | 11:30 AM
Lucky-13's Avatar
Default Re: (meg!)
i used krylon wrinkle black and mine looks straight.
Old Jul 11, 2007 | 07:49 AM
NTX
Guest
Posts: n/a
Default Re: (Lucky-13)
bump for more black vht/krylon
Old Jul 11, 2007 | 09:18 AM
dinko's Avatar
Default Re: (NTX)
i did this one with VHT
i did one last night with krylon, ill post pics later tonight
Old Jul 11, 2007 | 10:48 AM
NTX
Guest
Posts: n/a
Default Re: (dinko)
yeah post some close ups as well
