no start
Old Apr 16, 2007 | 03:38 PM
innes887's Avatar
Default no start
the other day when ireplaced the neg batt cable the alt or the batt only produced 10 volts when the car was on but when i turned on accessories it droped to 8 and died. i replaced the cable again thinking it was a bad ground cable the car still acted the exact same. when i turned the car off and unpluged my autometer gauges wiring and radar detector the car wouldnt even turn over. no crank, no fuel pump priming, fuel gauge doesnt work, right blinker light on the dash is light up. i charged the battery but it still dosent start. i was thinking it was the main relay or the ecu. can someone help me please
innes887's Avatar
by the way its an 89 crx dx with a manual trans
Old Apr 16, 2007 | 04:01 PM
EF_LSVtec's Avatar
Default Re: no start (innes887)
did you try jump starting it? Did you check all your fuses?
Old Apr 16, 2007 | 04:14 PM
innes887's Avatar
yeah i checked all of them and i tried jumping it but nothing. ive seen on other posts that the main relay is the common problem but i dunno
Old Apr 16, 2007 | 04:29 PM
innes887's Avatar
i just checked the ecu and it blinks once then pauses then blinks twenty times. does that mean its code 20?
Old Apr 16, 2007 | 09:04 PM
innes887's Avatar
would the code 20 make my fuel pump not prime or turn on?
Old Apr 18, 2007 | 01:20 PM
innes887's Avatar
now when i open my passenger side door 3 dash lights come on even when the key isnt in the ignition. brake lights dont work, reverse lights dont work, and headlights wont work. could it just be a bad ground or somthing? i put a 2 gauge ground wire coming from the battery to the stock location on that holds the clutch cable.
Old Apr 22, 2007 | 04:53 PM
innes887's Avatar
ok i just tested the starter and its dead. does anyone know what would cause the no fuel pump priming or the lighs on the dash?
DSMAddicted
32
Apr 20, 2024 02:14 AM
Lars421
Apr 28, 2018 11:04 AM
JDM_ego2033
Apr 20, 2018 10:04 AM
d_bravo06
Apr 21, 2017 06:00 AM
saxman
16
Aug 26, 2005 10:00 AM
