valve cover paint
Old Apr 16, 2007 | 03:35 PM
Kr4nG's Avatar
Default valve cover paint
my vlave cover just recently started to chip its stock black paint and im desciding on repainting it. but i want to origanal wrinkle like honda gets. i know that they get it by putting it in heat or like an oven. but i wanted to repaint it teal or greenish type. and i dont want a gloss or any type of shinyness. i want to get the same wrinkle like honda gets. and i wnat to know what type of paint i should look for. high heat of course. but what else there is another type i need. can anyone help me out on what to look for and where i can get it. thanks
Old Apr 16, 2007 | 03:52 PM
tomithy's Avatar
buy wrinkle paint
Old Apr 16, 2007 | 03:56 PM
Kr4nG's Avatar
easy to say but is it really called that? haha and how long does it last cause i need wrinkle paint and at the same time high heat paint
Old Apr 16, 2007 | 04:11 PM
TheTeg's Avatar
This would be the opportune situation to go ahead and get that aftermarket valve cover you've been eyeing. And don't settle for one of the cheap knock off ones... they leak. Unless of course money doesnt permit, then high heat O'reilly's engine enamal is your friend.
Old Apr 16, 2007 | 04:17 PM
Padawan's Avatar
Darth ModerVader
Default Re: valve cover paint (Kr4nG)
https://honda-tech.com/zerothread?id=1938668
The Krylon paint discussed in that thread also comes in black if you prefer the stock look.
Old Apr 16, 2007 | 05:27 PM
Kr4nG's Avatar
im not asking on how its done but thanks a lot on the link. im not buying a new valve cover cause its pointless i just want a new color to my valve color to match my teal body color. and since the black is already pealing i want to repaint it. so a near by shop should have the paint i need right. all i need is paint thinner, a paint brush to get all spots with paint thinner, paint by krylon i guess and an oven.
Old Apr 16, 2007 | 07:55 PM
soundFX's Avatar
Default Re: (Kr4nG)
high temp wrinkle
Old Apr 16, 2007 | 08:03 PM
mtpktz.'s Avatar
Default Re: (soundFX)
If you're looking to do something creative, you might want to check out this thread:
https://honda-tech.com/zerothread?id=1827204
Old Apr 16, 2007 | 08:57 PM
98GSRDC2's Avatar
primer and wrinkle with clear finish
Old Apr 19, 2007 | 07:13 PM
John M's Avatar
Default Re: valve cover paint (98GSRDC2)
VHT works the best
Old Apr 20, 2007 | 06:34 PM
SHG_Riley's Avatar
Default Re: valve cover paint (John M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John M &raquo;</TD></TR><TR><TD CLASS="quote">VHT works the best </TD></TR></TABLE>
Yeah VHT, go to summitracing.com ,they have the high heat wrinkle in black and red
Old Apr 20, 2007 | 07:22 PM
SneezinCD5's Avatar
I used some wrinkle paint from Autozone and I am very satisfied with the outcome.
Before:
After:
Old Apr 20, 2007 | 07:26 PM
SneezinCD5's Avatar
Default Re: valve cover paint (SneezinCD5)
I also painted a couple VC's and an intake pipe awile back for my Accord.
Old Apr 21, 2007 | 08:43 AM
CBURKE's Avatar
My red wrinkle, and they make is it black. I noticed the longer you let it site before butting it on the better it comes out.
Old Apr 21, 2007 | 08:54 AM
SneezinCD5's Avatar
Default Re: (CBURKE)
Put it in the oven at around 220 for about 5-10 minutes. Makes it look oem with two coats.
Old Apr 27, 2007 | 09:36 PM
Kr4nG's Avatar
i want to find a green wrinkle paint to match my teal color. but i cant find any green wrinkle its more on the lighter green side im looking for. any suggestions where i can get it? and all the vc look great btw. has anyone heard of the stone paint where you spray it and it comes out like stone? well what if i spray that first and than spray my green normal paint by krylon over it. how will that turn out if i cant find a green wrinkle paint.
Old Apr 28, 2007 | 10:32 PM
SneezinCD5's Avatar
Default Re: (Kr4nG)
Don't know if it will work or not, but I painted my VC's with the same paint that I shot my car with. Hasen't messed up yet and still looks like it did the day I painted them. Been about 2 1/2 years now. You can try to put the base/clear over the wrinkle paint. Haven't tried it but don't see why it wouldn't work, other than maybe a reaction between the two. But worth a shot.
Old Apr 29, 2007 | 05:42 PM
91ed9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SneezinCD5 &raquo;</TD></TR><TR><TD CLASS="quote">
dude you make me want my old accord back
for a sweet accord!
this was mine traded it for my CRX
Old Apr 29, 2007 | 11:47 PM
doubleshotz's Avatar
VHT
for powdercoat/oem lookalike
prep
prime
paint
sit
bake
Old May 1, 2007 | 02:44 PM
Ghostdog16's Avatar
Default Re: (doubleshotz)
what primer should be used?
Old May 1, 2007 | 04:52 PM
SneezinCD5's Avatar
Default Re: (Ghostdog16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ghostdog16 &raquo;</TD></TR><TR><TD CLASS="quote">what primer should be used?</TD></TR></TABLE>
You really don't need to use any primer with the wrinkle paint. As long as you prep it good
Old May 1, 2007 | 05:34 PM
Ghostdog16's Avatar
Default Re: (SneezinCD5)
What all needs to be done to prep it? Im assuming you would use aircraft remover to remove the old paint then scuff the surface with sandpaper so the paint sticks am i correct?
Old May 3, 2007 | 08:44 PM
Kr4nG's Avatar
they need to start making more diff. types of wrinkle paint cause i need green
Old May 4, 2007 | 03:45 PM
sr20b13's Avatar
Default Re: (Kr4nG)
i do valve coveres with base tough clear
Old May 4, 2007 | 04:48 PM
Kr4nG's Avatar
today i tried something to see how it will look. i didnt strip the old paint off yet so i took a green paint that i want to use and just sprayed a line over the regular black wrinkle. and it came out like it was green wrinkle. so im just gonna buy black wrinkle and spray the green over it so it looks like its actually green wrinkle.
