electric load detector
Old Apr 16, 2007 | 01:43 PM
bobss's Avatar
Default electric load detector
iam geting code 20 electric load detector does anybody know how to fix this problem not sure where to even start with this one thanks in advance guys
Old Apr 17, 2007 | 02:06 PM
innes887's Avatar
im trying to find the same thing you are cus i got that code. did your ecu blink once then pause then blink twenty times?
Old Apr 17, 2007 | 02:49 PM
slowman's Avatar
I took way too long
Default Re: (innes887)
IIRC, the ELD is housed in the underhood fuse box on the passenger side strut tower. I believe the only fix is to replace the entire unit (fusebox).
Old Apr 17, 2007 | 03:05 PM
juice91si's Avatar
Default Re: (slowman!)
try replacing and cleaning your engine bay grounds. worked for me.
Old Apr 17, 2007 | 07:32 PM
bobss's Avatar
Default Re: (juice91si)
yes i replaced the whole fuse box works great now thankx guys
Old Apr 18, 2007 | 12:26 AM
innes887's Avatar
thats the only fix? where did you get the fuse box?
Old Apr 18, 2007 | 02:41 AM
bobss's Avatar
i got mine from the junk yard cos i need it asap i will buy a new one soon
Old Apr 18, 2007 | 05:22 AM
ChickenH's Avatar
replaced mine its in the fusebox. didnt fix it. it was bad grounds.
Old Apr 18, 2007 | 09:38 AM
bobss's Avatar
Default Re: (ChickenH)
i made severel grounds to jus to be on the safe side ,.....
Old Apr 18, 2007 | 01:44 PM
innes887's Avatar
cus i got this code right when i replaced my neg batt cable with a thicker one and put the end of the cable onto the headder bold. then i switched it back to the stock location but still nothing
Old Apr 18, 2007 | 02:58 PM
bobss's Avatar
trying maken more grounds urself or replace the fuse box under the hood
Old Apr 18, 2007 | 11:04 PM
innes887's Avatar
make more grounds off of what? the neg batt cable? i sanded down the grounding points that ive seen but still no fix. i took apart the under the hood fuse box and its all fine( no burnt termanals, no blown fuses, everything checks out) what else can i do?
Old Apr 19, 2007 | 03:04 AM
bobss's Avatar
check fuses in the car driver side ,, yes neg side batt terminal .
Old Apr 20, 2007 | 06:40 PM
Rywire's Avatar
Default Re: (bobss)
make sure a green/red is in position b19
Old Apr 20, 2007 | 08:57 PM
Mr.Death's Avatar
Default Re: (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">make sure a green/red is in position b19</TD></TR></TABLE>
Explain.
Thanks
Old Apr 21, 2007 | 08:24 AM
Rywire's Avatar
Default Re: (Mr.Death)
it gets pulled out when doing obd0 vtec, so check
Old Apr 22, 2007 | 07:11 PM
innes887's Avatar
what do you mean by doing an obd0 vtec? like a swap?
ntegrar
Aug 6, 2012 01:09 PM
DOHCED8
14
May 23, 2009 10:06 AM
jason.az1
Dec 13, 2008 10:01 AM
Bo0sted4Do0r
Apr 27, 2006 09:38 AM
Oren
Feb 22, 2005 12:26 PM
