what is a chipped ecu?
i tried to search but found no results. I'm just wanting to know what a chipped ecu really is before i buy one. I need an ECU so idk if i should buy a virgin or a chipped one. and are there any downfalls to a chipped ECU?
A chipped (or socketed) ECU is one which, as its name implies, has a socket where a chip can be plugged in. This chip can be programmed (often with a free application such as Crome or Uberdata) with custom fuel and ignition maps, VTEC crossover, rev limiter, etc., that will allow you optimise the settings to your particular setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eibach95Civic »</TD></TR><TR><TD CLASS="quote">i tried to search but found no results. I'm just wanting to know what a chipped ecu really is before i buy one. I need an ECU so idk if i should buy a virgin or a chipped one. and are there any downfalls to a chipped ECU?</TD></TR></TABLE>
Depends on who is doing the chipping or who has done the chipping. I would suggest reading the informaiton provided on this site
http://www.phearable.net/tech/....html
I would also reccomend him and his work
to phearable
to phearable
b4spaceage
Feb 3, 2006 03:57 PM
