FS: Auto-Cross Car Columbus, Ohio
For sale is a 1995 4 Door neon highline color is dark green Located in COLUMBUS OHIO
Price is $3500 obo
This car has been set up and has been run in the local STS auto-x class, and has everything needed to be a competitive car. I bought the car to use as a weekend auto-x car but ended up with two cars and needing to sell one.
the car still has the heater core installed but the AC compressor has been removed.
The car must be run on premium fuel because of the mopar ECU. The stock ECU is included and can be switched out if you want to run a lower octane gas
Engine: Est. HP~190
-55K mile short block (From 1997 Stratus with aluminum finned oil pan).
Block was in superb condition with clean oil and virtually no carbon
buildup or cylinder wear.
-Cold Air Intake with K&N filter.
-Lightened/Underdrive Crank Pulley
-Multi-angle Valve Job (Performance Research, Columbus, OH) on Original 1995 Cylinder Head & Cam. Multi-Layer Head Gasket.
-Aluminum (not plastic) Intake Manifold
-Automatic Transmission (larger) Throttle Body
-Mopar Performance ECU
-EGR Delete
-DOHC Muffler
-Polyurethane Engine Mounts.
-Solid Bobble Strut
-Rebuilt alternator
Suspension/Drivetrain:
-3.94 Ratio Transmission Swap
-Shortened Shift Lever and Aluminum ****
-Booger Shifter Bushings
-Koni Adjustable Shocks, Slotted Mounts and Crash Bolts Allowing Camber
Adjustment Front and Rear
-Custom Wheel Alignment
-Mopar High-Rate Springs
-Polyurethane Front Suspension Bushings
-Front Control Arm Brace
-Front Shock Tower Brace
-Rear Shock Tower Brace
-Bigger Front Sway Bar
-Adjustable Rear Sway Bar
Exterior is stock with Falcon Azenis tires mounted on stock wheels.
There is paint fade on the roof and front bumper but there are no major dents on the car.
also there is a bunch of extra parts that will go with the car including AC compressor that worked fine before it was removed, radiator, polyurethane bushing kit, and the stock ECU
That cover should probably be painted, if i don't get to it. Picture also shows cd player delete
Modified by KJF553 at 2:30 PM 4/24/2007
Price is $3500 obo
Engine: Est. HP~190
-EGR Delete
-DOHC Muffler
-Solid Bobble Strut
-Rebuilt alternator
MLBZ521
Apr 13, 2011 08:07 PM
