HELP... Alot of smoke (oil steam) coming out of the valve cover
theres alot of smoke coming from the valve cover (that valve that goes back into the intake)......why is this happening?......
you could have a leak in the piston rings that is leaking oil into the cover and there might also be a little leak on the cover creating smoke.. there are soo manythings but can't really say without any pics or more detail..
its called blow-by , just google and read about it. pull the dipstick , is it comming out of there too? your rings arent sealing properly. when the plug ignites the air/fuel mixture , the exhaust gasses are slipping by the piston into the bottom end of the engine.
never totally damaged man , unless you throw a rod through the block. everything else can be fixed for a price. he just needs rings , pistons and new holes badly. cost you about 500 bucks to make it new again if you do the labor yourself approx.
underpressure02
Oct 17, 2003 06:29 AM
Ri5e
Feb 11, 2002 05:10 AM
