Will JDM length header+ JDM CAT + USDM B-pipe match the length??
Old Apr 15, 2007 | 09:05 PM
ednyboo's Avatar
Default Will JDM length header+ JDM CAT + USDM B-pipe match the length??
Hello, i've researched and found out jdm header wont fit usdm catback
Will JDM length header+ JDM CAT + USDM B-pipe this combination match the length??
anyone have done it? thanks
Old Apr 15, 2007 | 10:14 PM
berettagtz117's Avatar
I dont know, I have wondered same thing though! Somebody pop in w/ answer
Old Apr 15, 2007 | 11:12 PM
RagingAngel's Avatar
All B-series production headers (yes I can finally use it in a plural sense ) are all the same length.
It's the cat that is shorter, and the JDM midpipe is longer to compensate.
So JDM/USDM header + JDM cat + USDM B-pipe = midpipe is too short.
You will require a JDM midpipe.
Old Apr 16, 2007 | 08:49 AM
HSPxNick's Avatar
Default Re: (RagingAngel)
can't you just replace it with a test pipe?
Old Apr 16, 2007 | 08:58 AM
rcar97's Avatar
Default Re: (erasa510)
Best legal thing to do is JDM header, custom cat, usdm exhaust <U></U> It is a bolt in affair if you use a T1R tp but you'll pollute like a *****. Get a good aftermarket cat and get someone to weld up the correct flanges and O2 sensor bung.
Old Apr 16, 2007 | 09:02 AM
HSPxNick's Avatar
Default Re: (rcar97)
yea, i also hurd it isn't that hard to get muffler shops to custom your cat to fit.
Old Apr 16, 2007 | 10:09 AM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erasa510 &raquo;</TD></TR><TR><TD CLASS="quote">yea, i also hurd it isn't that hard to get muffler shops to custom your cat to fit. </TD></TR></TABLE>
Cost me $20 cash and had it done twice (2 different setups). Once was to make a test pipe that connected my stock 94CX downpipe to an aftermarket exhaust. The second time was to cut & lengthen the aftermarket exhaust to mate up to a JDM ITR cat. The guys obviously pocketed the money both times. Moral of the story, bring cash with you and it's cheap & easy...
PS: Call ahead & make sure they can squeeze you in...
Old Apr 16, 2007 | 03:20 PM
ednyboo's Avatar
Default Re: (94eg!)
found out that USDM midpipe is abuot 5" or so short to put with jdm header+cat
i ended up extending the stock midpipe..
Old Apr 16, 2007 | 03:51 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (ednyboo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ednyboo &raquo;</TD></TR><TR><TD CLASS="quote">found out that USDM midpipe is abuot 5" or so short to put with jdm header+cat
i ended up extending the stock midpipe.. </TD></TR></TABLE>
I wouldn't worry about it. As long as it was welded good, it isn't gonna hurt the resale...
Old Apr 16, 2007 | 04:12 PM
ednyboo's Avatar
Default Re: (94eg!)
Hope that viet muffler shop dude did a good welding job..
i think he did.. but i mean,, it just looks too nasty lol..
Old Apr 26, 2007 | 04:08 AM
Petah's Avatar
But what about this:
JDM 4-1 + JDM cat + USDM GSR cat back system of your choice
Will this combination work? I heard that the 94-99 GSR systems are longer to compensate for the shorter USDM GSR cats. Anyone tried this?
Old Apr 26, 2007 | 04:59 AM
SMSP's Avatar
Default Re: (Petah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Petah &raquo;</TD></TR><TR><TD CLASS="quote">But what about this:
Will this combination work? I heard that the 94-99 GSR systems are longer to compensate for the shorter USDM GSR cats. Anyone tried this?</TD></TR></TABLE>
That should work for the 94-99 GSRs. In 2000, the GSR B pipe was change to match the length of the LS and ITR stuff.
JDM header is 5/8" - 3/4" longer than the USDM headers.
Old Apr 26, 2007 | 05:10 AM
Petah's Avatar
Default Re: (SMSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">
JDM header is 5/8" - 3/4" longer than the USDM headers.</TD></TR></TABLE>
Thanks for the response, but this setup "JDM 4-1 + JDM cat + USDM GSR cat back system of your choice" will also work on a 97 ITR chassis....correct?
jdm_94
May 15, 2009 09:22 PM
ITR3189
Aug 1, 2007 09:13 PM
ednyboo
Apr 22, 2007 07:40 AM
austrian type-R
Feb 16, 2004 02:39 PM
2k1TypeR0610
Sep 28, 2001 08:16 AM
