use heat on a ball joint?
Old Apr 15, 2007 | 07:01 PM
.Kevin.'s Avatar
Default use heat on a ball joint?
My ball joint wont "pop" out so I was thinking about putting heat on it. will that wreck it? I am replacing the rubber boot so if that melts i could care less.
Also as much as I dred going to a dealer or shop I would but I know what they are going to say.
me-"so can you pop my ball joint on and repace the boot?"
them-"sure it will be $70 to do it."
me- "ok sounds good to me."
5 min goes by....
Them-"yeah we wont be able to replace the boot because the ball joint is actually shot."
me-"can you give me 5 min I need to lube myself before I bend over."
Modified by Ep_Kevin at 8:28 PM 4/15/2007
Old Apr 15, 2007 | 07:03 PM
excivicboy96's Avatar
Default Re: use heat on a ball joint? (Ep_Kevin)
what have you used to try to get it out?
Old Apr 15, 2007 | 07:05 PM
EG2Driver's Avatar
Default Re: use heat on a ball joint? (excivicboy96)
Won't pop out from the control arm or pop out of the knuckle?
There is a C-Clip holding the ball joint on the knuckle, you know?
Old Apr 15, 2007 | 07:15 PM
.Kevin.'s Avatar
Default Re: use heat on a ball joint? (DeadEnd9009)
I've used almost everything.
-The good ol' fork
-The trick where you put the rachet between the control arm and jump on the hub.
-jacked the suspension up, put a poll under it and let the suspension down hoping it would pop.
-Used the honda tool from autozone... Basically the screw just dug into the metal.
-Used one of those tools where you clamp it on the a arm and then screw a bolt up and it puts pressure on the ball joint to pop it out.
-put wd40 on the thing and let it sit for awhile.
-hit it with a hammer.
I am trying to just pop it out to change the boot. Not replacing the entire ball joint.
Old Apr 15, 2007 | 10:25 PM
EGhatch87's Avatar
There is a C-Clip holding the ball joint on the knuckle, you know?[/QUOTE]
his right, there is a C-Clip holding the ball joint to the knuckle
Old Apr 16, 2007 | 12:56 PM
EGEKDC2S2000's Avatar
dynamite might work......
Old Apr 16, 2007 | 04:43 PM
.Kevin.'s Avatar
Default Re: use heat on a ball joint? (EGEKDC2S2000)
will heat work?
Old Apr 16, 2007 | 04:45 PM
MyEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ep_Kevin &raquo;</TD></TR><TR><TD CLASS="quote">will heat work?</TD></TR></TABLE>
Heat is a mess! it'll melt but the balljoint will morph and drip onto the arms and other suspension components.
Old Apr 16, 2007 | 05:53 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGEKDC2S2000 &raquo;</TD></TR><TR><TD CLASS="quote">dynamite might work......</TD></TR></TABLE>
So would chuck norris.
Old Apr 16, 2007 | 06:09 PM
Quitripin's Avatar
Default Re: use heat on a ball joint? (97Ej6mike)
Hit the lower control arm on a good surface near the ball joint with a good size hammer/Dead blow (metal head) it will pop off. As far as removing the ball joint try using a press. I've seen people hammering the ball joint out.
arielb1
Oct 31, 2008 12:29 PM
chibiko
Jun 6, 2007 08:45 PM
GruvyTune
Aug 10, 2004 11:30 PM
Vp Special K
17
Jan 6, 2004 02:08 PM
riack
Jun 27, 2002 08:51 PM
