Is it Jun 3 camshaft and what valve spring are they? (with pic)
Is me again, hope you guys can help me out.
My friend found something for me in the junkyard, and the guy told him it is Jun 3 cam but didn't know what valve spring it is. Can anyone tell?
I know the box is from Jun, and the serial no. is correct, but the spring just don't looks like Jun to me. And for the camshaft, yes, it looks like Jun cam, but I can't tell which type it is.
Please help, thanks!
Modified by Spoonson at 8:59 PM 4/15/2007
Ya, I did the same thing last night, and confirmed the box is from Jun. But the spring looks like OEM typeR spring, so I want to know if there is any Jun valve spring owner here can clarify that for me?
Another photo for the cam. Please kindly let me know if you know which type it is, THANKS!
Exactly Zap.
What about the spring? any comments? Because I see some yellow and blue on the inner spring, and wonder whether they are OEM honda Type-R's.
Pump for comments about the valve spring in the picture, thanks!
If it is Jun valve spring, the inner ring shouldn't be any yellow and blue mark on it, am i correct?
You are not going to tell from pictures, have someone check the seat pressure and open pressure of the springs, see if they match Jun specs. If you do not know what that means, find someonr that does.
get the #s off the end of the cam, that will tell you if they are JUN or not.
> what # should be stated at the end of the Jun 3 cam? Thanks!
look at the end of the cam POST THE #s here and we can tell you. i dont have my JUN 3 cams sitting in my lap and im not going to walk out to the garage and get them.
ek2k
Apr 11, 2005 02:53 PM
NT?
