Intermittent CEL 22 and CEL 1
Yesterday I drove to Winston Salem which is about an hour away and when I got there in the city I was just cruising and all of a sudden I had a check engine light so before I stopped I did a pull to see if vtec was engaging. And it wasn't and sure enough I stop jump the connector and get code 1 and code 22. So I shut the car off for about 2 min while I was getting gas, I get back in a continue to my friends and vtec works now and no cel. Same thing happened to me today. I mean I know if I just shut the car off for a few min and start it back up I won't have any problems I just don't like goofy problems like that. While back I had to drive my car with my TPS unplugged for about 3weeks until I could get the TPS problem fixed. I was pretty much running for ECT and MAP inputs, and it was a little rich, As soon as I got the TPS fixed I threw a code 1 for o2 sensor. So I guess what I am trying to ask is would the o2 being defective cause the code 22? I have a spare o2 I can put in but I live in an apartment complex. Thanks for reading and bump if you veiw please!
Footnotes: Will a faulty o2 sensor ( code 1 ) cause a code 22 (vtec) since it is intermittent?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaggy420 »</TD></TR><TR><TD CLASS="quote">code 22 could be because you might be low on oil. if it gets a little low then the vtec pressure valve wont open. not sure how to fix the o2 sensor one other than replacing it. good luck</TD></TR></TABLE>
It is an intermittent problem that has only occured twice, in the past week. Oil is not the problem, and I really don't believe that vtec pressure switch is fauly either, I think it has something to do with the o2.
MintyDip
Jan 21, 2002 09:37 AM
