fuel and injectors dont fit right!
I bought bosch style precision 1000cc injectors and a mr gasket performance fuel rail but the injectors dont fit snug in it any suggestions to make it fit?
Are you aware that Mr Gasket makes two different fuel rails? One for normal injectors and one for Bosch style injectors. Maybe you got the wrong one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonlude »</TD></TR><TR><TD CLASS="quote">Are you aware that Mr Gasket makes two different fuel rails? One for normal injectors and one for Bosch style injectors. Maybe you got the wrong one?</TD></TR></TABLE>
Yep. Or you need to modify your o-rings in order so the injectors fit. I use a dremel to open the o-ring up.
yeah i got the one for bosch style but they dont fit where the injector goes into the fuel rail. The injector is loose in there seems like with fuel pressure it may leak.
airwalk07143
Dec 30, 2008 05:56 AM
