How do I take off my head lights? 1991 integra (NOOB I know)
I have taken off the middle lights and the outside corners. The middle lights I cannot get off. I have taken out any screws in sight. Seems to be connected to a black frame which I cannot get it off of as well. I can feel that it is connected to 2 main areas but I can't get to them. I know the question sounds dumb but I need some help.
If thier is a key word to search for let me know. THANKS.
I think you have to take off ur front bumper to get ur headlights off
http://www.autozone.com/az/cds...s.htm
Bumper Removal
1. Use the Phillips screwdriver to remove the bumper turn-signals by unscrewing the screw (1 on each housing) and pull out. Save the screws in the container. Unplug the wire harnesses from the back of each assembly and set the housing to the side.
2. Unbolt the four bolts (2 behind each bumper light housing) and place them in the container. You will need to use the wrench and extension to reach. 12mm socket for these, I think.
3. Unscrew the 4 bumper mounting screws (2 on either side of the bumper, in the wheel well) and place them in the container.
4. Unscrew the 2 clips from the bumper. They are on the underside of the bumper, behind the lip, on either side of dead center. They unscrew and then you have to pry out the small casing that they reside in.
5. Lift and remove the bumper by sliding it forward. Its not heavy, but a friend would be helpful, just so you don’t scratch it. Lay it on the blanket.
If you have any other questions about your da go to g2ic.com
