Removing Underdrive pulley-bolt is out
Old Apr 15, 2007 | 01:49 PM
hu's Avatar
hu
Default Removing Underdrive pulley-bolt is out
I have the bolt out. Now how do you remove the pulley? I don't want to screw it up. It is an Unorthodox Crank Pulley.
Old Apr 15, 2007 | 01:51 PM
clemsoncb7's Avatar
Default Re: Removing Underdrive pulley-bolt is out (hu)
just pull...
Max
Old Apr 15, 2007 | 02:49 PM
hu's Avatar
hu
This thing has only budged 1/8 of an inch. What a pita. Is there any other trick aside from just pulling?
Old Apr 15, 2007 | 02:58 PM
Hawkze_2.3's Avatar
Default Re: (hu)
Spray it with some WD-40 or PB Blaster and then tap in towards the engine gently to break it loose. The you might be able to pull it off easier...
Old Apr 15, 2007 | 03:35 PM
.BigSexy's Avatar
most hood white kid
Default Re: (Hawkze_2.3)
what Brandon said. I've never had ANY trouble with mine...I dunno what could be the problem. They do make crank pulley remover/puller you can rent from autozone...if all else fails, try that
Old Apr 15, 2007 | 03:57 PM
clemsoncb7's Avatar
Default Re: (egcoupe94)
The little pin can be a pain, but tap it slight with a mallet or something
Max
Old Apr 15, 2007 | 06:26 PM
lude98SH's Avatar
Default Re: (clemsoncb7)
hmmm rubber mallet maybe just tap it on either side.
Old Apr 15, 2007 | 07:22 PM
mgags7's Avatar
it should have a little side to side play, get a screwdriver in behind it and try prying just slightly each side and go back and forth....
Old Apr 15, 2007 | 07:34 PM
117's Avatar
117
I've never had one just come off like the stock pulley. I use a gear puller very gently, and it comes off just fine.
His_Dudeness
Sep 2, 2010 06:11 AM
knightsef-eg
19
Sep 28, 2008 03:46 PM
bseriescrxsi
Mar 31, 2008 12:11 PM
DC4 Rasta
Aug 27, 2007 12:50 PM
SuicideSlide
Oct 9, 2004 08:27 AM
