The making of my custom interior.. PICS
Old Apr 15, 2007 | 01:27 PM
Smallpox33's Avatar
Default The making of my custom interior.. PICS
BEFORE:
i stripped the car and started weight removal
removed power seatbelt motors and lines.
270k miles on my carpet
Before:
after:
I fixed the rusted spots as well this was causing cabin noise!
Fiberglass was applied to both sides of the wheel well
i also used sound deadener to make the interior sound and feel better.
The original headliner was tan, i covered it in black vynl
Integra LS seats weigh ALOT less then the stock seats and look and feel way better
Painting Time!
I picked up an Acura Legend map light from the junkyard and an ebrake and shifter boot.
Putting it together
added some rice
maplight and headliner
Finished!!
Old Apr 15, 2007 | 01:36 PM
Smallpox33's Avatar
Default Re: The making of my custom interior.. PICS (Smallpox33)
btw, i did the paintjob on the car, but thats a whole other thread of pics im to lazy to post.
Old Apr 15, 2007 | 01:39 PM
dt's Avatar
dt
Awesome work I am actually liking the contrast between the black and beige......
Old Apr 15, 2007 | 01:42 PM
JohnD1079's Avatar
I give you for the work. i am planning on doing sorta the same thing with mine, i have 2 accords, 1 is smashed and i wanna combine the tan + blue interior. QUestion for you, how long did it take to do all this?
Old Apr 15, 2007 | 01:44 PM
GhostAccord's Avatar
to the clean look. Very nice work.
What year LS seats will work, I'm looking for new seats, mine are toast!
Old Apr 15, 2007 | 01:51 PM
Smallpox33's Avatar
Default Re: The making of my custom interior.. PICS (JohnD1079)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnD1079 &raquo;</TD></TR><TR><TD CLASS="quote">I give you for the work. i am planning on doing sorta the same thing with mine, i have 2 accords, 1 is smashed and i wanna combine the tan + blue interior. QUestion for you, how long did it take to do all this?</TD></TR></TABLE>
At first i just wanted to clean it up a bit, and then i started going to the junkyard and getting small things like integra clocks and shift boots. when i bought the ls seats i decided to do the whole thing.
it took me 6 weeks total but i would say about 2 weeks of actuall work on the car like every chance i had.
oh and the seats are from a 95, its hard to mount them if you really wanna know pm me.
Old Apr 15, 2007 | 02:02 PM
gianinline's Avatar
Spray painting carpet won't last a wash or two.
Best way it is using the dying materials.
But "A" for the effort and "A" for the final result!
Old Apr 15, 2007 | 02:06 PM
Smallpox33's Avatar
Default Re: (gianinline)
lol my carpet isnt painted, the bottom door trim is.
its been about 2 months since ive done this, it still looks the same.
Old Apr 15, 2007 | 03:30 PM
5G_Vtec's Avatar
Awesome job! I want to do this to my 95 Accord. Well not a color change, but strip the whole interior and clean it really good.
Old Apr 15, 2007 | 03:37 PM
twotonecivic's Avatar
Default Re: The making of my custom interior.. PICS (mustbeballiin)
that really turned out pretty nice man
Old Apr 15, 2007 | 03:42 PM
droppedakord09's Avatar
that turned out real nice, im in the process of doing the same thing to my 94 coupe
Old Apr 15, 2007 | 03:49 PM
kiddcarbuff's Avatar
i JSut did that as well on my cb7, went frmo blue to black, howd u get the teggy seats in? i used the SEM dye to do all my plastic with. looks good!
Old Apr 15, 2007 | 04:00 PM
5G_Vtec's Avatar
One question though, did you use one of those carpet steam cleaners you can rent or something else? I was thinking of using a carpet steam cleaner, but I don't know if the ones that I've seen have a smaller steamer on it.
Old Apr 15, 2007 | 04:21 PM
Smallpox33's Avatar
Default Re: (95_Vtec)
thanks for the compliments guys, i had that steam cleaner lying around at my rents house, so i used it. its good because it sucks up the water though
i basically ended up dumping grease lightning on it and spraying it with a hose while scrubbing it with a scrub brush lol.
Old Apr 15, 2007 | 04:44 PM
low97accord's Avatar
Default Re: (Smallpox33)
i just did this in my car, gotta finish some stuff up (black carpet and seats) and ill be happy...how does that sound deadener work?
Old Apr 15, 2007 | 04:49 PM
Smallpox33's Avatar
Default Re: (low97accord)
it works alright, it mostly stops the sounds of little rocks or debris bouncing up in the undercarriage. also make it feel more airtight.
i thought about dynomat, but the point was to lose wieght not gain it.
Old Apr 15, 2007 | 07:56 PM
momstaxi's Avatar
Old Apr 15, 2007 | 08:48 PM
i might have to try that out...how much more weight do you think dynamat will add? i was planning on doing some type of sound deadening once i installed my new carpet
Old Apr 15, 2007 | 10:19 PM
Smallpox33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by low97accord &raquo;</TD></TR><TR><TD CLASS="quote">i might have to try that out...how much more weight do you think dynamat will add? i was planning on doing some type of sound deadening once i installed my new carpet</TD></TR></TABLE>
alot. thiers this guy on cb7tuner who covered his entire car in dynomat it then put the interior back on it was like 200 pounds!!!
Old Apr 15, 2007 | 11:33 PM
Twixle's Avatar
ate my pixel
Nice two-tone paint job.
Interior looks good, I'm kinda surprised that the spray paint isn't chipping or anything.
Old Apr 16, 2007 | 04:37 AM
streetxdreamer's Avatar
Default Re: (accord2021)
wow that actually looks real nice
Old Apr 16, 2007 | 04:51 AM
TouringAccord's Avatar
H-T Order of Merit
Would you mind explaining the steps you took to mount the Integra LS seats into the Accord?
Also, did the height of the seat change? Meaning, do you now sit higher, lower or at the same height compared to the stock seats?
Old Apr 16, 2007 | 07:58 AM
Persian Virgin's Avatar
Doesn't look too bad! Good job.
Honda Tool
Detailing
Mar 7, 2010 09:13 AM
jdmralliart
May 26, 2008 05:14 PM
$LiLPooky$
May 7, 2007 07:57 PM
lightsleeper
Jan 23, 2005 12:20 PM
NINJASPY
20
Aug 24, 2003 09:53 PM
