Boosting 94 si
Old Apr 15, 2007 | 11:06 AM
Depeche's Avatar
Default Boosting 94 si
Hey guys, quick question. In a 94 si, the h23, is 300-350 horse doo-able safely on stock internals and head? And also, for that power range, can anyone reccomend a turbo? Any ideas on a good turbo set up (intercooler, piping kit, BOV, wastegate) would help immensely, as this will be my first FI car.
My group of friends all build civics, and know alot about FI, but wanted to get a Luder's input on the best turbo for this specific application.
Old Apr 15, 2007 | 11:13 AM
DfwBB6's Avatar
Default Re: Boosting 94 si (Depeche)
watching carefully.......tick...tock..tick
Old Apr 15, 2007 | 02:58 PM
street_ride14's Avatar
Boom .........
Old Apr 15, 2007 | 03:58 PM
esedulerp5tenin's Avatar
Default Re: (street_ride14)
it'll prolly hold it for about a month
then you will go boom and be FORCED to build your bottom
Old Apr 15, 2007 | 04:37 PM
ilikehonda's Avatar
Default Re: (esedulerp5tenin)
300hp is safe with a good tuner/ software. 280 is even safer.
Old Apr 15, 2007 | 07:26 PM
Attaus's Avatar
There are plenty of threads with setups in em.. just look and read up.
Get an SC61.. mo' powa!!
Old Apr 16, 2007 | 09:32 AM
preludestud11's Avatar
Default Re: (Attaus)
my goal was 300hp on a stock block h23. I got to 242, before my tuner advised me not to take it anyhigher. That was a on small turbo though. t3/to4b at 10psi, ramhorn manifold, and 3inch dp. tuned on neptune.
Old Apr 16, 2007 | 09:36 AM
GraphiteMW's Avatar
Default Re: (preludestud11)
What kind of ram horn manifold are you currently using? The thing you should be worried about is the piston lands usually go out before anything.
Old Apr 16, 2007 | 10:29 AM
nonvteclude's Avatar
Default Re: (GraphiteMW)
on a stock bottom end h23 i would not recommend going that high. that motor will not last more than a month or two. stick around 220 to 250 max on a low psi.
Old Apr 16, 2007 | 11:57 AM
Default Re: (nonvteclude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude &raquo;</TD></TR><TR><TD CLASS="quote">on a stock bottom end h23 i would not recommend going that high. that motor will not last more than a month or two. stick around 220 to 250 max on a low psi.</TD></TR></TABLE>
EXACTLY on what i'm planning
Old Apr 16, 2007 | 12:46 PM
hu's Avatar
hu
If you want your motor to last, you should upgrade it. Balanced crank, pistons, rods, valves and valvetrain.
Old Apr 16, 2007 | 06:32 PM
Attaus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">on a stock bottom end h23 i would not recommend going that high. that motor will not last more than a month or two. stick around 220 to 250 max on a low psi.</TD></TR></TABLE>
You should know better.. you can't make generic statements like that when it comes to boost, Hondas, and tuning.
First of all, its the ringlands on the H22 that crack, not the H23. I don't think I've heard of H23 ringlands cracking.
Secondly, the H23 has a slightly lower CR, which will give you a little room on the power. I've seen anywhere from 230whp lasting 2 months to 320whp lasting a year and a half and still going on the H22. The H23 has just as much capability.
Old Apr 16, 2007 | 06:43 PM
GraphiteMW's Avatar
Actually i've heard alot about h23 ring lands cracking and going out. genocides ring lands went out i believe.
Old Apr 17, 2007 | 10:24 AM
Depeche's Avatar
Do i have to worry about head damage on the stock 23? Or is it mainly the bottom i need to upgrade?
Old Apr 17, 2007 | 11:50 AM
Default Re: (Depeche)
bottom end
Prudz_lude
May 6, 2007 05:54 PM
Preludetuner
Apr 23, 2003 06:07 AM
EH2DX
Mar 23, 2003 08:01 AM
andlude
Feb 5, 2003 06:41 PM
