New ABS modulator unit
Old Apr 15, 2007 | 08:29 AM
Rhood's Avatar
Default New ABS modulator unit
Hi
Can someone help me with changing out the ABS modulator on 1995 Accord EX, I got a new one and I would like to change it out my self any tips or how to's ? would be very helpful.
Thanks
Rhood
Old Apr 15, 2007 | 08:38 AM
JDM_DC4_Fanatic's Avatar
Default Re: New ABS modulator unit (Rhood)
remove the lines and plugs going to it. Unbolt it. Reinstall the lines and plugs. Bleed the brakes from the master, then the modulator, then at all 4 wheels and your good to go.
Old Apr 16, 2007 | 09:37 AM
Rhood's Avatar
Default Re: New ABS modulator unit (JDM_DC4_Fanatic)
Thanks
Can you please tell me the sizes kind of tools I will need to do this job.
Old Apr 16, 2007 | 11:38 AM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">remove the lines and plugs going to it. Unbolt it. Reinstall the lines and plugs. Bleed the brakes from the master, then the modulator, then at all 4 wheels and your good to go.</TD></TR></TABLE>
When I changed my abs modulator, I never bled all the brakes. I bled the abs, thats it.
OP, you'll need a 10mm line wrench and I believe a 12 or 14 mm wrench..
Old Apr 19, 2007 | 06:48 PM
Rhood's Avatar
Default Re: New ABS modulator unit (walker111)
Walker111
Thanks for the tips, but what do you use to plug brake lines so the fluid wont flow out.???????????
95_red_dc
Oct 17, 2008 11:03 PM
DoHcV-tEc
Oct 17, 2008 11:02 PM
bonh
Jun 28, 2007 12:15 PM
JimmyAtlantis
Dec 8, 2005 10:38 AM
PM-Performance
Jul 1, 2003 03:13 AM
