Clifford LED Volt Output
Does anyone know what's the voltage output for the LED on a Clifford 50.5x system? I want to stop using the LED it came with and use 2 small led that I can mount somewhere else. But before I do that, I wanted to check the volt output.
you should be able to measure it with a volt meter... though many leds are 5v, many are also designed to be run with 12v but have in-line resistors to drop the voltage to what it needs...
technine
Audio / Security / Video
Aug 30, 2002 09:23 PM
