had a problem at the track blowing oil
Old Apr 15, 2007 | 04:14 AM
crxsir23's Avatar
Default had a problem at the track blowing oil
i installed my catch can went to the track and in the first 2 passes i lost a 1 1/2 Q of oil before i hoked the hoses to the catch can i started the car up to make sure i had every thing right were the 14mm plug was on the left side it was blowing some oil when i reved it, but i'v seen cars with oil coming up there hoses before so i thought it would be ok. Have i over looked something? As far as my engine goes it was ok, before it smoked at idol but i have bad seals on my turbo it had all of it's normal power. No power loss.
I SEARCHED
Modified by crxsir23 at 6:56 PM 4/15/2007
Old Apr 15, 2007 | 07:51 AM
crxsir23's Avatar
Default Re: had a problem at the track blowing oil (crxsir23)
didn't think i would get any help on his subject but il figure it out
Modified by crxsir23 at 1:34 AM 4/16/2007
Old Apr 15, 2007 | 11:39 AM
nsxmatt's Avatar
Your post is hard to read, but from the looks of it either your catch can is hooked up wrong or you have alot of blowby either from ringlands or something else major.
Old Apr 15, 2007 | 02:05 PM
Garage 808 Hatch's Avatar
it probably is oil slosh, when you launch, it runs up the oil galleys, into the tubes, is it set up to drain back?
Old Apr 15, 2007 | 05:49 PM
crxsir23's Avatar
Default Re: (Garage 808 Hatch)
no it does not have a drain back. i was wanting to know how much oil was going to collect in the catch can so i did not put one on it and i have seen people with out one so i left it off. i guess the main thing is i can put a drain back hose on the catch can but am i starving the engine from oil some were is this normal
fixed my first post
Modified by crxsir23 at 6:59 PM 4/15/2007
kid.dynamite
Jan 24, 2016 09:32 AM
nick_622
Honda Civic (2001 - 2005)
10
Apr 20, 2009 04:54 PM
itr1244
Dec 13, 2002 12:37 AM
PY2KITR1060
May 4, 2002 10:20 PM
PY2KITR1060
May 4, 2002 01:30 PM
