Ebay rotors
Old Apr 15, 2007 | 12:00 AM
zirac50's Avatar
Default Ebay rotors
which one is better to get drilled/slotted rotors or just slotted? I am buying one from ebay and still confused which one is better. Some say drilled are not good and prone to warp easy. Need advice!
Old Apr 15, 2007 | 09:17 AM
ProjectTib's Avatar
well i got drilled/slotted rotors off ebay and ive had em on my car for like 2 yrs now and they are fine... that is also my daily driver. I have heard the same thing though, I think if you constantly use your brakes like if you live in the city or sit in heavy traffic all the time then I would get just slotted... otherwise you should be fine.
Old Apr 15, 2007 | 09:26 AM
syntax.'s Avatar
Blank rotors are the best. Even Porsche and Ferrari admit that drilled/slotted rotors have no performance advantage, they just sell more cars.
Modern brake pads dont create gasses that need to be vented.
Old Apr 15, 2007 | 10:49 AM
l2yanE's Avatar
Default Re: (syntax.)
Ive bought mine, drilled and slotted off of ebay for 160$ shipped. Ive had them over a year and a half, and really put them to the test ive, and they have still to this day not warped or cracked. ebay rotors FTW
Old Apr 15, 2007 | 10:58 AM
93sivtec's Avatar
Actually they do make differences.....just not like u would think.Both styles are more meant for the track,and while both will help reduce breaking tempratures,they both reduce suface area which is huge for braking.....hence why u upgrade to a bigger rotor and caliper when u are really upgrading ur brake system.
I have read and heard that slotted rotors are meant for very heavy/constant breaking,and the slots actually work as a razor to remove a small amount of the brake pad,to minimize pad glazing,and give a nice new pad surface for every corner.
If u want a cooler look and cooler brake temps,than get them,but If u want to make a difference in ur braking perfomance I would suggest a good set of pads and steel braided brake lines.They are the 1st,and the most cost effective step in a more reponsive,reliable breaking system.Or if u can afford it bigger calipers paired with bigger rotors will make the biggest difference.Good luck
Old Apr 15, 2007 | 07:14 PM
zirac50's Avatar
Default Re: (93sivtec)
thanks guys for your input. I think im going to get drilled/slotted rotors it's only 160 anyway. Im not looking for high performance brake system. I agree drilled/slotted looks cooler. I believe that all rotors get warped when they get worn. I have my oem warped right now so i need them replace really bad.
thanks again.
Old Apr 16, 2007 | 09:44 AM
idrivealude's Avatar
Default Re: Ebay rotors (zirac50)
i say if ur going to go ebay for rotors do not get any generic cross drilled ones. they will crack after a while, better to go with a name brand like powerslot or brembo and be safe. also cross drilled is only best for very hard braking, like for track cars on a street car, non crossdrilled and non slotted is better and pair them with some good pads and ur good to go.
Old Apr 16, 2007 | 10:12 AM
NirVTEC's Avatar
Default Re: Ebay rotors (idrivealude)
$25 Parts Store rotors FTW!
Old Apr 16, 2007 | 12:04 PM
esedulerp5tenin's Avatar
Default Re: Ebay rotors (NirVTECn2o)
i aint trusting such an important item such as BRAKES from ebay
my .02
Old Apr 16, 2007 | 12:45 PM
hu's Avatar
hu
Default Re: Ebay rotors (esedulerp5tenin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esedulerp5tenin &raquo;</TD></TR><TR><TD CLASS="quote">i aint trusting such an important item such as BRAKES from ebay
my .02</TD></TR></TABLE>
For real...
I got Brembo blanks from tirerack.com
Old Apr 16, 2007 | 01:04 PM
BlownH23a
Guest
Posts: n/a
i have brembos(drills) from ebay..they work fine and i also have a set of generic ceramic pads for my track days and they work awesome.
Old Apr 16, 2007 | 01:56 PM
93sivtec's Avatar
Like These?
http://cgi.ebay.com/ebaymotors...QrdZ1
THose would be fine.
Old Apr 16, 2007 | 05:41 PM
MooJenLude's Avatar
I have 4 slotted/drilled rotors from ebay...been through a lot of hard breaking, cornering, and abs pumps...they work great, no glaze, no warp and they make your pads shiney and new looking...
jayponz
Aug 3, 2013 08:49 AM
fatpride111
Suspension & Brakes
Sep 3, 2009 01:17 AM
zirac50
Apr 5, 2007 09:37 PM
Han Solo
11
Nov 9, 2006 12:03 AM
ZensokuEK
13
Oct 25, 2003 01:22 PM
