can all 94-01 integra 2 door coupe doors fit fine? any problems with install?
Old Apr 14, 2007 | 07:56 PM
CrazyRexBoy's Avatar
Default can all 94-01 integra 2 door coupe doors fit fine? any problems with install?
hey bros...i tried searching about doors on there but cant seem to find an answer....
i need to change my door on my 99 GSR which is a 2 door coupe....can all doors fit for my model from 94-01 or is there gonna be a problem when i buy a 94 door ...thanks guys...i need help on this asap....thanks in advance...
Old Apr 14, 2007 | 09:38 PM
94allmotor's Avatar
Default Re: can all 94-01 integra 2 door coupe doors fit fine? any problems with install? (CrazyRexBoy)
their wont be np everything bolts right on
Old Apr 15, 2007 | 01:55 AM
98GSRDC2's Avatar
Default Re: can all 94-01 integra 2 door coupe doors fit fine? any problems with install? (94allmotor)
94-01 doors should all be interchangable
Old Apr 15, 2007 | 03:47 AM
F20Cteg's Avatar
Default Re: can all 94-01 integra 2 door coupe doors fit fine? any problems with install? (98GSRDC2)
The electrical connectors on the doors are different. Not exactly sure on the year change.
Old Apr 15, 2007 | 09:29 AM
Default Re: can all 94-01 integra 2 door coupe doors fit fine? any problems with install? (F20Cteg)
thanks guys....ima go get a door asap...again thanks..
Old Apr 15, 2007 | 10:23 AM
Innovative LS's Avatar
When you get a used door make sure there is a refund or exchage policy for the junk yard or that the door has never been hit, like if you find some one parting out a car. A buddy of mine did the same thing but the door had been hit but in a inconspicuous spot where you could not tell but the window frame was out of wack. I helped him install it wow what a pain. good luck,
Red1ine
Nov 7, 2005 01:42 PM
RiCeRTeG
Sep 14, 2004 10:36 PM
impound
Jan 26, 2004 04:04 PM
camera obscura
Feb 10, 2003 07:50 AM
SexyTeg
Oct 25, 2002 11:24 PM
