High compression junkyard built D16A6.
Old Apr 14, 2007 | 07:19 PM
snm95ls's Avatar
Default High compression junkyard built D16A6.
Discuss.
The name of the game is guess the pistons.
Old Apr 14, 2007 | 07:24 PM
simply's Avatar
Default Re: High compression junkyard built D16A6. (snm95ls)
**** looks gross
what kind of pistons are those?
Old Apr 14, 2007 | 07:39 PM
snm95ls's Avatar
Default Re: High compression junkyard built D16A6. (Cindy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cindy &raquo;</TD></TR><TR><TD CLASS="quote">**** looks gross
what kind of pistons are those? </TD></TR></TABLE>
Hahaa. that's the name of the game.
You would seriously never guess in a million years.
Air cooled
2 valves per cylinder
Not Honda
From Japanland
Old Apr 14, 2007 | 08:14 PM
Old Renegade's Avatar
suzuki swift GT
Old Apr 15, 2007 | 01:13 AM
MrDark's Avatar
Default Re: (Old Renegade)
D17A2!!!!
Old Apr 15, 2007 | 03:44 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (MrDark)
old school gallant
Old Apr 15, 2007 | 03:55 AM
alterdcreations's Avatar
Default Re: (GarageAlchemist)
i would say peice of ****
look out of a v twin
Old Apr 15, 2007 | 06:00 AM
spun Vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist &raquo;</TD></TR><TR><TD CLASS="quote">old school gallant</TD></TR></TABLE>x2
Old Apr 15, 2007 | 06:47 AM
cafcwest's Avatar
late 70's Honda Goldwing
How about you clean that **** up first before building an engine. One goober of oil/crud falls onto a bearing surface as you are installing a cap, torque it down, start turning over the engine and score that bearing surface all to ****. Go.you!
Old Apr 15, 2007 | 11:38 AM
tireiron's Avatar
looks like a rock from japan?
Old Apr 15, 2007 | 11:41 AM
soulpwr's Avatar
Default Re: (tireiron)
I'm gonna go with V-twin
Old Apr 15, 2007 | 02:58 PM
B16CRXT's Avatar
Did you even hone the cylinder bores? You really shoulda hot tanked that block before installing the pistons.
Old Apr 15, 2007 | 03:09 PM
BIGTUNA's Avatar
Default Re: (B16CRXT)
I already know
Old Apr 15, 2007 | 03:22 PM
high_revs's Avatar
no idea.
Old Apr 15, 2007 | 09:38 PM
snm95ls's Avatar
Lol. Tuna knows.
Yeah, I seriously slapped a block together like that.
They came out of a 1970 Yamaha XS 650. I was disassembling the block to check it out and had these laying around. They looked to be about the right size so I slipped them into the bores and they fit perfectly.
Pretty much done for a WTF factor.
Modified by snm95ls at 9:01 PM 4/16/2007
Old Apr 15, 2007 | 09:42 PM
spork motorsports's Avatar
* B A N N E D *
Default Re: (snm95ls)
awesome
Old Apr 15, 2007 | 11:33 PM
Broken Gearbox's Avatar
what kind of CR are you looking at?
Old Apr 16, 2007 | 04:53 AM
spun Vtec's Avatar
Default Re: (Broken Gearbox)
what is your piston to deck height?
what is your piston to wall clearance?
does the wristpin fit the stock honda rods?
Old Apr 16, 2007 | 05:11 AM
99exd16y8's Avatar
Default Re: (spun Vtec)
subscribed
Old Apr 16, 2007 | 05:24 AM
high_revs's Avatar
intresting
Old Apr 16, 2007 | 03:29 PM
had a strong feeling that it was a motorcycle piston...
Old Apr 16, 2007 | 06:48 PM
high_revs's Avatar
updates?
Old Apr 16, 2007 | 06:51 PM
CaseBone's Avatar
INTERESTING! me like!
Old Apr 16, 2007 | 08:01 PM
snm95ls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snm95ls &raquo;</TD></TR><TR><TD CLASS="quote">Lol. Tuna knows.
Lol. I did check out a few things while out in the garage today for the curious.
Yeah the bore may fit beautifully but nothing else about the pistons will work.
The dome is so high that it would contact the spark plug before it reached TDC.
The compression distance is too tall as well.
Old Apr 16, 2007 | 08:47 PM
spun Vtec's Avatar
Do you meen dome height or piston to deck height?
No such thing as compression distance.
