d16y8 swap turbo'd need some info
hey just did a swap 98 d16y8 into a 99 dx civic and i'm setting up boost got everything in couple problems
first my tack does not work anymore ? is there a different wire it should be on now that i've switch to obd2a ?
second it seems that my car is not charging the battery ? yes the altinator is fine and yes the battery is good and all the wires are there and the belt is tight i think it has something to do with the ecu change and the convertion harness any info ??
third if im hearing the car predetinating do i advance the timing?
any info will be greatly appreciated thanks!!
retard the timing, be sure to use the service connector under pass. dash.
as far as using a obd2b as opposed to A, i don't think you should be having any VSS issues. check the VSS plug for any stretched pieces.
Check all your fuses for the ALT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by custompainter »</TD></TR><TR><TD CLASS="quote">first my tack does not work anymore ? is there a different wire it should be on now that i've switch to obd2a ?</TD></TR></TABLE>
chassis->engine => obd2b->obd2a harness needed. the pinouts are different.
i found the voltage problem come to find out the wire came unclipped from the starter i thought there wasn't enough power so thats fixed
now how do i retard the timing from under the dash ? cant i just turn the dizzy back a little ?
well yeah, but you have to bridge the service connector under the dash b4 you retard the timing by the dizzy, or you ecu will try to compensate
shawnperolis
25
Aug 17, 2010 09:52 AM
