fuel system upgrade
Old May 28, 2002 | 05:56 AM
92intb18a's Avatar
Default fuel system upgrade
need parts (manufacturer) recomendations for a fuel system upgrade. ie. (fuel rail, injectors, adj fuel reg, filter, fuel pump). I've seen a few out there like: AEM, Holley, Venom. Also does anyone know the fuel line connector size? (6AN or 8AN?) Since I'm at it, I want to change to stainless braided lines. Thanks in advance!!!!!!!!!!
Old May 28, 2002 | 06:00 AM
Farnsrocket's Avatar
Default Re: fuel system upgrade (92intb18a)
search for Dustin's archived post on his fuel sysem.............it's sweet!
Old May 28, 2002 | 06:47 AM
zilverz's Avatar
I have an upgraded fuel system .... Holley fuel pump ... AEM F Rail and AEM FPR .. but have yet to tune it ... a quality air/fuel ratio meter they say is Greddy and its like $200+ sooo im just gonna prob buy an ECU tuner insted..
might want to check and see if they ever made any more of those Weapon R Fuel pressure regulators .... when i needed mine ... they were out of stock for 6 more months and all they had was the Pink/Purple color but it has a FPR gauge on the side of it ... pretty snazzy
Old May 28, 2002 | 07:55 AM
92intb18a's Avatar
Default Re: fuel system upgrade (zilverz)
Did you keep the stock fuel filter and injectors or did you swap it for an after market ones? By the way what fitting size did you use?
Old May 28, 2002 | 08:02 AM
zilverz's Avatar
i dont remimber exactly ... but ill give you the Model #s off the boxes and they fit with all the stock parts ...
Yes i did use the stock fuel injectors...... I SHOULD have changed them out because now i got to tear the fuel rail back off to get to them ... so i would do it all at one time if i were you .... im getting some of those 310cc saturated injectors off groupbuy ... ummm as for the filter... i just bought the Highest grade from NAPA ..... if yours hasnt been changed in a long time .. might as well change it .... i dont know/think the AEM filter would be worth all that money they want
remimber too .. if you get the AEM FPR your gonna need an fuel pressure gauge at some point .. to help properly tune your fuel if you leave it set the same way it comes out of the box .. i think its set to like 45psi ? or something ... then do the proper ECU reset it should run fine ... i changed the port out inside the AEM FPR and put it back together and i have no idea what the PSI is set to .. i need a gauge hehe
Old May 28, 2002 | 08:11 AM
92intb18a's Avatar
Thanks! Yeah, I plan to upgrade the injectors since I'm already in there. Since this is my only daily commuter, I need to find out the exact fittings for the hoses so as not to make too many trips to the local race part store. Hopefully I can finish this off in 1 weekend.
k24egturbo
Oct 19, 2010 08:41 PM
rewerbcrx
Oct 19, 2005 08:31 AM
Joel_MN
Aug 17, 2003 11:59 AM
ramz7887
Jun 11, 2003 09:32 PM
Hispeed
Jul 30, 2001 10:12 AM
