Valve Adjustment- locknut torque
Old Apr 14, 2007 | 05:49 PM
vinuneuro's Avatar
Default Valve Adjustment- locknut torque
It doesn't specify a value in the helms..what is it?
Old Apr 14, 2007 | 05:56 PM
92hondalude's Avatar
Default Re: Valve Adjustment- locknut torque (vinuneuro)
10 i think.
but you have to have a flat head screwdriver holding the screw and then tighten the nut, so you cant use a torque wrench.
Old Apr 14, 2007 | 06:13 PM
m00nr0ck Si's Avatar
Default Re: Valve Adjustment- locknut torque (92hondalude)
I always get the locknut snug and then go back and torque all of them to 14 lb./ft.
try marking where the screw slot is with a marker and re-checking it after torque...
Old Apr 14, 2007 | 06:16 PM
117's Avatar
117
It is in the Helms. 14 ft*lbs.
Old Apr 14, 2007 | 06:30 PM
vinuneuro's Avatar
Default Re: (117)
****..I'm missed the diagram that has it. Nonetheless, how do you keep the adjustment screw from moving while torquing the locknut to spec...or is it not an issue?
Old Apr 14, 2007 | 06:43 PM
117's Avatar
117
It's usually not an issue if you put a bit of torque on the nut when you are doing the valve adjustment. I found that if I don't put enough torque on the nut at the beginning, when I use a torque wrench on it, the clearance will get too tight. I find that if I can keep the rotation of the torque wrench less than 90 degrees when torquing the nuts to spec, the clearance will pretty much stay put.
Old Apr 14, 2007 | 06:48 PM
Jonas97SH's Avatar
if you are going to be doing this often Honda makes a tool for it, it is a Tappet Locknut Wrench Part #: 07MAA - PR70120 I dont know if you can get it through any part stores but there may be one commercially available.
Old Apr 14, 2007 | 08:54 PM
vinuneuro's Avatar
Default Re: Valve Adjustment- locknut torque (Jonas97SH)
I got this..I think it should work well, good reviews:
http://www.amazon.com/Alltrade...r=8-1
Btw, do I want to set the clearance looser or tighter to spec?
Modified by vinuneuro at 12:04 AM 4/15/2007
Old Apr 15, 2007 | 06:48 AM
577HondaPrelude's Avatar
on the tighter side of the spec is what you want.
Old Apr 15, 2007 | 01:51 PM
mattsnooz's Avatar
Default Re: Valve Adjustment- locknut torque (577HondaPrelude)
tighter is better for performance and efficiency , but too tight will be disasterous. so don't go more than the factory manual says but get as close to the maximum tightness as possible to ensure valves are closing and opening to maximize efficiency and prevent added heat / friction (from valves moving out of spec).
salaamq
Dec 27, 2011 07:33 PM
4door_gsr_ftw
May 4, 2003 04:57 PM
