Passenger Side Axle question.....
What axle is to be used on the passenger side of a 1990 CRX Si w/ B16a Y1 LSD swap? I have a 90-93 Integra axle in there now and it is too long. Do I need to make an SiR axle?
depends on which intermediate shaft you are using. go see http://www.hasport.com look under the axle tech.
I have an SiR intermediate shaft and SiR driver side axle. I also looked at the Hasport tech and didnt see much about passenger side, they really focus on drivers side.
...from the hasport.com website...www.hasport.com
Because it is longer, it will not work with 90-93 Integra axles. So, we will need build some SiR axles for this intermediate shaft. To do this, simply use a pair of 86-89 Integra axles with the 90-93 Integra inner CV joints. The reason for the 90-93 Integra inner CV joints, is their depth. The 86-89 Integra inner CV joints are shallow and will break easily.
hth
hth
