Throwing a code and sputtering on and off ........ need help identifying it ......
I get 4 quick lights, a long pause, and another single light. Then a pause, and it repeats the 4 and 1.
Someone help me figure out which one it is ..... my Helms is at home, and I got it on the way to work ....
I thought the slow lights were first. you sure its not 1 that blinks and holds, then 4 quick lights. Either way, check http://www.hybrid-k.com/tech/codes.html . if it is sputtering during idle, maybe it is the IAC (code 14). Remember the codes flash the tens number first, then the ones number. eg, 3 slow blinks then 5 quick blinks is 35. hth.
See my other post ......... on the EF, it blinks continuosly, not separately. Code 14 is 14 blinks in a row ......... found that out the hard way .......
andrewasf77
Feb 13, 2003 02:34 PM
