Check engine light
Old Apr 14, 2007 | 12:50 PM
NguyenDC2's Avatar
Default Check engine light
Well today it was raining outside and I decided to do 1 little drift. After I did that, my check engine light went on. My friend said something about checking the code.
This is what he told me:
on the passenger side, there should be a green adapter along the side kick panel.
pull that out and use a paperclip and loop the connection.
turn the key to on and read the "check engine" blinks.
What is the green adapter is he talking? Pictures would be nice. Thanks guys.
Old Apr 14, 2007 | 01:55 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Check engine light (IMviet)
See if this link helps ya.
https://honda-tech.com/zerothread?id=1834589
Old Apr 14, 2007 | 04:17 PM
NguyenDC2's Avatar
Default Re: Check engine light (tech8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech8 &raquo;</TD></TR><TR><TD CLASS="quote">See if this link helps ya.
https://honda-tech.com/zerothread?id=1834589</TD></TR></TABLE>
Alright, thanks man.
Old Apr 14, 2007 | 05:09 PM
hondadude's Avatar
Depends on WHAT YEAR Accord;
But this might help;
Old Apr 14, 2007 | 07:43 PM
NguyenDC2's Avatar
Default Re: Check engine light (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Depends on WHAT YEAR Accord;
It's a 2000 Special Edition Accord.
Old Apr 14, 2007 | 08:11 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
If it's a 2000 model, that is OBD II. It won't have that plug. It's a different universal OBD II plug, most likely under driver side dash.
You will need a OBD II code scanner. You can go to Autozone to get the code read for free.
Old Apr 14, 2007 | 09:38 PM
xluben's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech8 &raquo;</TD></TR><TR><TD CLASS="quote">If it's a 2000 model, that is OBD II. It won't have that plug. It's a different universal OBD II plug, most likely under driver side dash.
You will need a OBD II code scanner. You can go to Autozone to get the code read for free. </TD></TR></TABLE>
unfortunately autozone, orielly's, ect usually makes you put down a full deposit which they give back when you return it. i kinda find that to be a pain. you can get an obd1 code by using the jumper method.
it's the bottom left and fourth up on the right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
That you need to do is turn the ignition off, and using the piece of wire or paperclip, jump the spots I mentioned above. Basically stick one end of the paperclip or peice of wire into one prong on the connector and stick the other end of the paperclip or wire into the other prong.
Once you have done this, turn the key to the IGN position and watch your CEL light. It will illuminate in a series of flashes.
You will notice that there will be LONG flashes and SHORT flashes. All of the ECU trouble codes are two-digits. LONG flashes determine the TENS digit by the number of times it flashes, and SHORT flashes determine the ONES digit by the number of times it flashes.
ie. LONG-LONG-LONG-SHORT-SHORT-SHORT-SHORT-PAUSE
is the trouble code: 34
3 LONG flashes followed by 4 short flashes, then a long pause. If that is the only code the ECU is throwing, then the code will simply repeat until you remove the key. If, however there are more than one ECU error code, then you will see a different series of flashes followed by the long pause. Once all the ECU codes have been displayed, they will continuously cycle until you remove the key.
ie. LONG-LONG-SHORT-PAUSE-LONG-LONG-LONG-LONG-SHORT-SHORT-SHORT-PAUSE
is the trouble code: 21 and 43</TD></TR></TABLE>
here should be the codes:
http://www.c-speedracing.com/faq/05.php
Old Apr 15, 2007 | 03:37 AM
NguyenDC2's Avatar
Default Re: Check engine light (xluben)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xluben &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.c-speedracing.com/faq/05.php</TD></TR></TABLE>
Alright, thanks. for the tips.
CDN Yellow ITR
Nov 4, 2005 01:12 AM
mahin
Honda S2000
Jan 12, 2005 10:55 AM
xci_ed6
May 9, 2004 08:00 PM
HyperITR742
Jul 18, 2003 12:37 AM
integrater
May 7, 2003 11:52 AM
