change tranny fluid ???
Old Apr 14, 2007 | 12:07 PM
massh22gsr's Avatar
Default change tranny fluid ???
i ahve a 98 prelude (h22) with a manuel transmission, how should i fill my tranny, plus there is a hole maby 1 sq. in. on the front of the motor whats that there for , also what kind and how much tranny fluid / oil should i use thx.
Old Apr 14, 2007 | 02:24 PM
syntax.'s Avatar
Default Re: change tranny fluid ??? (massh22gsr)
on the lower passenger side of the tranny theres a plug that takes a 3/8 drive ratchet to loosen, thats the drain plug. about 3 inches above it theres another plug, it takes a 17mm socket iirc, and thats the fill plug. drive the car until its up to temp, then drain the fluid. It takes about 2 quarts to fill. if the car is on level ground, fill it until it overflows out the fill hole.
I'll take a guess and say that the plug on the front of the block youre talking about is just a water plug.
Old Apr 14, 2007 | 02:38 PM
m00nr0ck Si's Avatar
Default Re: change tranny fluid ??? (syntax.)
1 square inch hole is probably the tranny timing hole...its there so that you can view the timing marks on your flywheel when setting the ignition timing...
Old Apr 14, 2007 | 03:00 PM
massh22gsr's Avatar
Default Re: change tranny fluid ??? (dorkoftheyear)
3 in above the drian is the trans. mount one of those bolts woulnt be it right? is there was a pic that would be great
Old Apr 14, 2007 | 03:07 PM
massh22gsr's Avatar
http://i22.ebayimg.com/02/i/06/f8/53/64_3.JPG
would it be the bolt closest to the front
Old Apr 14, 2007 | 05:36 PM
syntax.'s Avatar
14 is the fill plug and 10 is the drain plug. Honda's new MTF fluid (with the white cap) has worked well for me.
Old Apr 14, 2007 | 06:31 PM
massh22gsr's Avatar
thankyou very much that was extremly helpful
northkai3
26
Sep 29, 2013 11:53 AM
AR-cb7
Apr 8, 2008 09:27 AM
CBR600OnTop
Dec 30, 2002 05:04 AM
pelotudo
Jul 21, 2002 02:33 AM
96Prelord
Jun 5, 2002 07:21 PM
