ITR Tranny rebuild need parts etc.
Old Apr 14, 2007 | 10:33 AM
jspecjoe's Avatar
Default ITR Tranny rebuild need parts etc.
I have read most of the posts about tranny problems, grinds, noises etc. I am not a rookie I know th trans is bad, and running gear oil or others thick fluid isnt going to work. So..........
Where do I get parts to rebuild my tranny? Syncros , and bearings, seals etc. I am sure there has to be a rebuild kit of some type. R trannys seem to go for 70-80 K and get weak. Where can I get the parts do do this or does anyone know a good place to send the tranny to?
Old Apr 14, 2007 | 10:34 AM
PrinceAli132's Avatar
Default Re: ITR Tranny rebuild need parts etc. (jspecjoe)
http://www.barancoacuraparts.com
http://www.gearspeedinc.com/
Ali
Old Apr 14, 2007 | 11:13 AM
92TypeR's Avatar
FSAE
Default Re: ITR Tranny rebuild need parts etc. (PrinceAli132)
I just ordered a set of GearSpeed brass 1/2 synchros and 3/4/5 carbon synchros for my spare ITR tranny.
Just from experience, the bearings on the input/output shafts rarely fail/wear. I would inspect them first before ordering the bearings, because most of the wear will be on the synchro sleeves.
Old Apr 14, 2007 | 04:19 PM
jspecjoe's Avatar
thanks its making noise like its a sweet JGTC car trans or something like that. And I just drove it back from Deals gap in TN with it whining all the way back
Old Apr 14, 2007 | 05:34 PM
D's Avatar
D
Default Re: ITR Tranny rebuild need parts etc. (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">IJust from experience, the bearings on the input/output shafts rarely fail/wear. </TD></TR></TABLE>
You're joking, right? Input shaft bearing failure is common as all hell.
Old Apr 14, 2007 | 10:56 PM
92TypeR's Avatar
FSAE
Default Re: ITR Tranny rebuild need parts etc. (D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">You're joking, right? Input shaft bearing failure is common as all hell.</TD></TR></TABLE>
No joke here. I've never personally seen any sort bearing failure or even wear on the transmissions I've taken apart, which isn't a large amount by any means. I don't doubt what you are saying, but I am surprised it is as common as you make it out to be when its not often spoken about.
Anyhow, to the OP, it is easy to tell if there is severe/abnormal bearing wear simply by inspecting. Unless you are pressed for time during your rebuild, I would recommend taking a thorough look inside before ordering unnecessary parts.
Old Apr 15, 2007 | 07:55 AM
jspecjoe's Avatar
sounds like solid advice to me thanks, what clutch do you like and who can I buy it from thats reputable
civic_66
Mar 30, 2008 07:24 AM
CPR
Jan 5, 2006 11:02 PM
AsianMullet
Mar 9, 2004 10:59 AM
Robb
Dec 16, 2003 08:55 AM
BenB
Nov 6, 2003 11:09 AM
