OBD2A SOHC -> OBD2A B SERIES CKP
I have a single cam harness with the three wire ckp, I am swapping a obd2 b-series into it (2 wire ckp) I need some information on how to rewire the sensor/harness. Haven't been able to find out any information on it so far. Any help will be appreciated. Thanks.
Blu is the signal, Wht is the ground. The Blk wire is just the shielding being grounded, which the B16A2 doesn't use.
And it's the CKF sensor you're messing with. The CKP is up inside the distributor (Civic's and Teg's, at least).
hope this helps
http://technet.ff-squad.com/ckftrick.htm
ToTriggerHappy
May 27, 2015 12:17 PM
billard
14
Mar 21, 2011 06:55 PM
jdmshawn95
Jan 16, 2011 09:18 AM
lostsol530
Jan 6, 2005 07:25 PM
