Replacing Clutch Fluid?
Can I use a one man brake bleederf set-up to bleed the clutch system? Can I just suck out the old fluid of the clutch rez. and re fill it with freash DOT3. Then crack the bleeder nipple on the slave cyl. attach the one man bleeder then just pump the clutch. Watching the fluid level to make sure it does not get low. Then stop when the fluid coming out of the slave is clear ?
