help itr tranny
did you guys put in enough tranny fluid? becasue recommended is 3 quarts and if u did then check for leaks make sure no leaks and if no leaks then trannys junk waiten to blow up. now if its leaking that could be the problem u drive its dripping away and den ends up low on fluid it ll make noise
4drferio
Apr 29, 2004 10:59 AM
