new track times!!! turbo sohc!
hey guys i finally made a trip to the quarter and came back happy!!! heres the reason why:
2.01 60 ft
5.27 330 ft
7.91@94mph
12.06@117mph
this was on 20psi on bfg dr's!!!
so what do u guys think??? this is in a stock weight 95 cx hatch...
2.01 60 ft
5.27 330 ft
7.91@94mph
12.06@117mph
setup is a tt/vitara z6 build, 57trim t3t04e, 680cc injectors...
i honestly thought that with a 94 in the 1/8 i should trap 119+ in the 1/4???
i sitll think the MBC is killing me, i cant SEE it fall off any on the autometer boost guage, but it HAS to be, im only picking up 23mph from the 1/8 to the 1/4...
Congrats!! So you only have a built bottom end?? (stock valvetrain) What's your reason for only running 20psi? other people on a vitara setup are running 24+ lbs. from what i've seen...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_man »</TD></TR><TR><TD CLASS="quote">FYI.. they now make 75.5mm vitara... </TD></TR></TABLE>
huh?
Since when?
More info!!!
huh?
Since when?
More info!!!
nice job!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jarvis199 »</TD></TR><TR><TD CLASS="quote">215/60-14</TD></TR></TABLE>
Kind of off topic, but i just got the same size bfgs for my car, but eye-ballin the tire against my car, which sits on H&R race springs, i'm not sure if they'll fit.
What kind of spring combo do you run with them tires?
a pic for me would be really super duper nice!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">
huh?
Since when?
More info!!! </TD></TR></TABLE>
x2
I would be switchin to d-series **** for sure........
huh?
Since when?
x2
huh?
Since when?
http://www.turbod16.com/viewtopic.php?t=35273
YCP is now producing 75.5mm as well.. I will be making a first order of these soon.. for more info follow the link.
huh?
Since when?
ill see what i cna do about a pic! im running agx struts and skunk2 coilovers and its kind of bouncy... if i hit the brakes hard going into a corner itll rub pretty good, but these tires are just strip tires anyway so i dont care
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_man »</TD></TR><TR><TD CLASS="quote">Thanks FJT..
I was just getting ready to post up that link...</TD></TR></TABLE>
Haha..you and me both.
I still say CP's FTW
Baller status
Agree with the above statement from Ginuwine....lower 60ft times and you're there. You should get 1.8 - 1.9 for sure.
Baller status
The tire you are running is 24.2" diameter. I would say that is why your trapspeed is down ~2mph compared to running a 22-23" diameter tire. That has been my experience.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Semtec »</TD></TR><TR><TD CLASS="quote">20psi is not crazy on stock sleeves...</TD></TR></TABLE>
hp is more important than psi also.
yes stock sleeves!!! been running this way for a year now!
my timing is backed down pretty far, and im actually thinking about turning it up some more on pump gas and seeing wht she will do, since my buddy just bought a new dynojet so we can slap it on and play some!
