Real Casrbon Fiber VIS Hood?
Old May 27, 2002 | 10:57 PM
tuphatt's Avatar
Default Real Carbon Fiber VIS Hood?
I bought a carbon fiber hood for my teg yesterday and can't tell if it is made by VIS. I can only tell you the fitment is good, there is a prop for the hood, It uses theOEM skeleton (although is only glued to hood in certain spots), The edges are round and not rough, Maybe this is the clue but there is a Yellow sticker with japense writing with 94 Int. next to it. It is like a 2x4 inch sticker.
My only problem is when I push down on the hood(closed) it is pretty flimsy?
Is this Normal?
[Modified by tuphatt, 11:57 PM 5/27/2002]
Old May 27, 2002 | 11:44 PM
B2FiNiTY's Avatar
Default Re: Real Carbon Fiber VIS Hood? (tuphatt)
It's flimsy because it is thin and light. VIS makes pretty good CF hoods. As long as you are happy with yours, that's all that matters.
Old May 28, 2002 | 05:42 PM
vtecnologist1's Avatar
Default Re: Real Carbon Fiber VIS Hood? (B2FiNiTY)
i have a vis and its flimsy as hell
but it lines up fine and my pins hold it down fine
Old May 28, 2002 | 07:01 PM
Civikun1945's Avatar
New User
I had the VIS hood. From my experience, it did not allign right and needed to cut a little on the hinge side. They had the washer nozzle holes. Also, it cracked with falling icicle from trees..........that's how i got rid of it.........
biggoofy
Paint and Body
Feb 26, 2009 05:51 PM
sambam27
Aug 24, 2003 04:35 PM
dbros_ek
Aug 30, 2002 05:07 AM
RHGSR01
Aug 22, 2001 09:47 PM
