IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor
Old Apr 13, 2007 | 01:31 PM
racerjohn's Avatar
Default IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor
i got a cel code and it came up as IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor. Anyone know where to find that sensor what one is it.
Old Apr 13, 2007 | 06:13 PM
Formula's Avatar
Default Re: IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor (racerjohn
What kind of engine do you have?
The sensor will probably be mounted on the Intake Manifold and will usually be mounted on one of the intake plenums. Different engines have them mounted in different places.
Old Apr 13, 2007 | 08:51 PM
immrtaltchnq's Avatar
might actually be under the intake plugged up into the intake if its stock,
Old Apr 14, 2007 | 09:31 AM
racerjohn's Avatar
its a ls turbo so it would be on the intake manifold but which one there is like 3 sensors
Old Apr 14, 2007 | 10:49 PM
Formula's Avatar
If I'm not mistaken the IAT sensor on a B18B engine should be on the number 1 or number 2 cylinder's intake plenum. The sensor will be plugged directly into the plenum and will have 2 screws holding it in.
Just look on the intake plenums and you can't miss it.
Griff911
Oct 30, 2014 06:38 AM
ewn1603
Sep 21, 2004 05:53 PM
BuddyC
Apr 20, 2004 04:54 PM
supernova
Dec 3, 2001 06:49 AM
