GS-R seats in a 95 civic
I have a 95 honda civic and I was wondering if the leather seats from any year integra GS-r would fit directly into my car with out any modification? Also if they do need modification how much would it take? I would like to kno for the front and rear seats.
94-01 front seats will bolt up without any problems. If you have a hatch, 2dr backrests with 4dr cushions will work for the rear. For a coupe/sedan, the 4dr cushion and backrest should fit with minor mods.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 »</TD></TR><TR><TD CLASS="quote">what about for a 96 civic? would they line up?</TD></TR></TABLE>
the front seats will bolt up but u need 4 door rear seats
3 out of 4 holes will line up on stock Integra rails. You will need to swap the inner rails for both of the front seats to have all 4 holes lined up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">94-01 front seats will bolt up without any problems. If you have a hatch, 2dr backrests with 4dr cushions will work for the rear. For a coupe/sedan, the 4dr cushion and backrest should fit with minor mods.</TD></TR></TABLE> Pretty sure you'll need longer bolts for the rear tab closest to the exhaust tunnel on both of the the front seats if they didn't come with the stock Integra ones, but they do align correctly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96GSRcx »</TD></TR><TR><TD CLASS="quote"> Pretty sure you'll need longer bolts for the rear tab closest to the exhaust tunnel on both of the the front seats if they didn't come with the stock Integra ones, but they do align correctly.</TD></TR></TABLE>
I know I had to get longer bolts for the JDM Recaros I put into my hatch. However, my hatch had Integra seats when I bought it and it used normal bolts. But I wonder if the original owner somehow swapped the EG rails onto them because the buckles were blue (blue interior in white hatch
).</TD></TR></TABLE>
Sounds possible, I've never done any rail swapping with oem seats though.
).</TD></TR></TABLE>Sounds possible, I've never done any rail swapping with oem seats though.
jadugartir
Nov 14, 2009 07:13 AM
ShinotakuX
Jul 8, 2007 05:01 PM
hatch34
14
Feb 6, 2007 06:08 PM
