00 civic si check engine flashing
https://honda-tech.com/zerothread/1901557... use this to get the code
when i check the codes the abs light flashes 54, 7, 9 and the check engine light stays on all the time.
is there a way to romove the ckf?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo18coupe »</TD></TR><TR><TD CLASS="quote">when i check the codes the abs light flashes 54, 7, 9 and the check engine light stays on all the time.
is there a way to romove the ckf?</TD></TR></TABLE>
the only way to shut the light off is to replace the sensors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19slocivic97 »</TD></TR><TR><TD CLASS="quote">if its blinking it means its catalist damaging, probably because of a missfire or other fuel problem, need code</TD></TR></TABLE>
If you're driving and the CEL is flashing at you, the above answer is correct.
cogs200
Feb 5, 2006 08:35 AM
