Odometer
Old Apr 13, 2007 | 10:47 AM
rknop's Avatar
Default Odometer
I had a different engine put in my car and every since the odometer hasn't worked. Is there a cable or something that may not have been connected? Where do I look and what do I look for?
Old Apr 13, 2007 | 01:46 PM
hondadude's Avatar
Default Re: Odometer (rknop)
What "COLOR" is the car?
Does the speedo needle work?
Old Apr 13, 2007 | 04:21 PM
rknop's Avatar
Default Re: Odometer (hondadude)
Yes, speedometer works. 1994 LX is the year and model.
Old Apr 13, 2007 | 05:56 PM
hondadude's Avatar
Well if the speedo is working it means the VSS on top of the differential is okay.
sorta strange it happened right at the exact time of an engine swap though.
You could open up the cluster and look for cracked solder joints or poor connections; other than that a junkyard cluster swap is the easy way to go.
Old Apr 14, 2007 | 04:34 AM
rknop's Avatar
Thanks for the quick responses! I'll check it out and keep you posted.
Old May 1, 2007 | 10:00 AM
mwallen's Avatar
I'm having the same issue we replaced the engine and shortly after that my odometer has stoped working -- we replaced the instument cluster and that didn't fix it so if you figured it out please let me know.
malx
Sep 17, 2017 05:50 PM
siregcivic
Oct 10, 2011 10:43 AM
axtran
Jun 6, 2006 02:23 PM
h22HatchEG
May 31, 2006 01:30 PM
bgundy87
Sep 5, 2004 07:22 PM
