Kick Panels: Where did you route power?
Old Apr 13, 2007 | 10:26 AM
MilanoCivic97's Avatar
Default Kick Panels: Where did you route power?
im building my kick panels right now and have run into an issue. i have already moved my ecu to allow room for the panel on the passenger side but that is also the same corner my power cables run through and if i leave it there it will run directly behond the components in that kick panel. would it be ok to leave them there or should i reroute or shield the cables somewhere else?
Old Apr 14, 2007 | 05:22 PM
regal1975's Avatar
Default Re: Kick Panels: Where did you route power? (MilanoCivic97)
usually you will not pick up noise via speaker wires due to the higher voltage those wires typically carry vs pre-amp level signal wires.. but if it is a problem, just be sure they cross at 90 deg angles or simply run the wires directly down the center of the pass footwell as far as you can..
AEK9
Jun 7, 2011 01:20 PM
vidanator
Audio / Security / Video
Feb 25, 2006 06:34 PM
TurboTeG4
Jul 19, 2003 11:42 AM
Skitals
Feb 27, 2003 11:20 AM
Volcom
Dec 30, 2001 11:49 AM
