QUICK ? ABOUT TRANNY FLUID CHANGE (I SEARCHED)
Old Apr 13, 2007 | 09:39 AM
TEAM JDM-P's Avatar
Default QUICK ? ABOUT TRANNY FLUID CHANGE (I SEARCHED)
Ok i need to change my fluid, my tranny grinds in third sometimes and the tranny is pitch black in color not normal. One question what fluid should i use between the GM syncron mesh thing or the honda one but i dont now withch one to pick the GM cost me about 8buks a 1/4 and do i buy synthetic nor non-synthetic and if i choose the Honda one , witch one should i buy . Another ? is how many 1/4's on a 94 acura integra Rs 5-speed. Your help will truely be appreciated thanx a lot.
Old Apr 13, 2007 | 09:40 AM
TEAM JDM-P's Avatar
Default Re: QUICK ? ABOUT TRANNY FLUID CHANGE (-=ADVAN=-)
ohh and is there a transmission filter or no if yes where is it located thanx.
Old Apr 13, 2007 | 12:18 PM
myfirstdc2's Avatar
should take about 2 qts. and no theres no tranny filter. u might want to go with a heavy weight. that usually helps out with minor grindings.
Old Apr 13, 2007 | 09:06 PM
TEAM JDM-P's Avatar
Default Re: QUICK ? ABOUT TRANNY FLUID CHANGE (myfirstdc2)
with one the honda stuff or gm
Old Apr 13, 2007 | 09:31 PM
Blahblah718293's Avatar
up to you. between honda and gm.
and if you did research you should know that the tranny takes about 2.2 quarts
Old Apr 14, 2007 | 07:15 AM
Padawan's Avatar
Darth ModerVader
Just pick up 3 quarts of MTF at your local Honda or Acura dealer, and you'll be all set.
Old Apr 14, 2007 | 07:59 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
There is no choice between synthetic or non. You either get Honda MTF and dump it in, or get GM Synchromesh Friction Modified and dump it in.
My tranny has 247K miles on it, using GM SM FM the past 100K miles and has no grinds whatsoever.
Old Apr 14, 2007 | 11:01 AM
TEAM JDM-P's Avatar
Default Re: (PatrickGSR94)
ok im doing it as i type i drain out the fluid took of the speed sensor and their is no hole big enought that looks like i can dump the fluid in by the way i bought GM syc
FM one and also i drain out the fluid yet their is still fluid in the cylinder next to the brake master cylinder
Old Apr 14, 2007 | 11:17 AM
RaceMyGhost's Avatar
Default Re: (-=ADVAN=-)
wow. i dont think you should be doing this. THAT RESERVOIR NEXT TO YOUR BRAKE MASTER CYLINDER IS YOUR CLUTCH MASTER CYLINDER. THAT HAS NOTHING TO DO WITH YOUR TRANNY. Get some Redline MTL tranny fluid, get a fluid pump thingy (so you can extract the fluid from the bottle and pump it into the tranny via fill hole. ) and call it a day.
Old Apr 14, 2007 | 03:30 PM
Default Re: (RaceMyGhost)
just read this and dont destoy anything else
http://www.team-integra.net/se...D=301
if you already drained your clutch fluid then you can refill it with dot 3 brake fluid.
Old Apr 14, 2007 | 04:09 PM
skUnK2jdm's Avatar
Default Re: (Blahblah718293)
get oem honda oil for the tranny!
Old Apr 14, 2007 | 08:21 PM
TEAM JDM-P's Avatar
Default Re: (skUnK2jdm)
ok i changed it but i still have third gear grind how much more miles do i need to put to feel a difference
Old Apr 15, 2007 | 07:00 AM
Padawan's Avatar
Darth ModerVader
Well if the synchros are badly worn, they may simply be beyond the ability of the fluid to mask the symptoms.
Old Apr 15, 2007 | 07:20 AM
ac_attak's Avatar
Give it a couple weeks and see how it is then.
Old Apr 15, 2007 | 07:12 PM
j_bizach's Avatar
Default Re: (ac_attak)
searched my *explitive* this has to be like the 5th thread on what fluid to use and how to change fluid. Another useless thread.
Old Apr 15, 2007 | 08:16 PM
Default Re: (j_bizach)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_bizach &raquo;</TD></TR><TR><TD CLASS="quote">searched my *explitive* this has to be like the 5th thread on what fluid to use and how to change fluid. Another useless thread. </TD></TR></TABLE>
if it helps someone with their problem its not a useless thread.
this forum has been around for idk how long, but there are only so many questions that can be asked before people start repeating them.
JDM_CRX_PLEASE
Oct 1, 2007 03:16 PM
IntegraChick
May 13, 2005 05:45 PM
gsr2envy
Nov 15, 2004 04:12 PM
chahsiubow
Jun 29, 2004 08:33 PM
Money Hou$e
Apr 24, 2002 04:46 PM
