VTec wiring/Knock sensor HELP
okay here are the cars im working with.
1994 honda civic CX
and a
1994 honda civic EX
okay here is the story,
i had a B16 in my CX and took it out too sell the COMPLETE swap too my friend gave him my harness that is non vtec. I had to add the Vtec wires(2) and the knock sensor separetly from the harness on my cx so those stayed with me on the shell.
I gave him everything and he gave me his complete D16Z6 swap with his harness(EX) it has all the vtec wires already in the harness.
Well we put the B16 in his 94 EX using the harness i gave him everything plugged in but i completely forgot about the vtec wires and knock sensor wires/plugs that i had too keep on my car.
Now his car is already wired for vtec from the main plugs under the engine bay too the ecu is that correct?
if so what should i do too get his vtec wired up?
Splice extra wires into the vtec wires from the ecu too the engine bay into the vtec plugs/knock sensor?
Basically,
CLIFF Notes:
-94 Ex has non vtec harness
-B16 swap
-need too wire vtec again/knock sensor
-HELP
EDIT: i Need too add the knock sensor too his ecu plugs/pin's HELP, his d16z6 didnt have a knock sensor.
1994 honda civic CX
and a
1994 honda civic EX
Basically,
CLIFF Notes:
-B16 swap
-HELP
look at his ecu plugs and find the pin for the vtec and knock sensor. if there are already wires there follow the wires up to the big plug in the engine bay.take the other end of the plugs and plug it up..if there is an empty spot there make a wires and plug it in there instead of wireing it thru the wire wall and into the cabin
the car is has a VTEC harness, right? So then eveything plugs in, where the plug connet to one another by the passenger shock tower(the clip w/the most wires) there will be a Green/Yellow wire on the harnees on the car run your VTEC wire to that, a blue wire for oil pressure groumd the black wire and a red/blue wire for the knock sensor
so yuor saying just too basically splice it in too those! is this right.and these wires are on the actual car harness that goes too the main ecu plugs right.?
green/yellow wire-> Vtec
Blue-> Oil Pressure
BLK-> Ground on body
red/Blue->Knock sensor
i thought his car wouldnt have a knock sensor? i thought his stock motor the D16Z6 didnt have a knock sensor?
Blue-> Oil Pressure
PartyBoyy91
Oct 1, 2011 11:27 PM
Greg456
Apr 26, 2004 04:09 PM
quicksol95
Mar 19, 2004 01:50 PM
SpeedRaciN'
Dec 6, 2001 09:52 PM
