Losing Power!!!!
Old Apr 13, 2007 | 07:56 AM
sambo_666's Avatar
Default Losing Power!!!!
Hey guys, i'm losing power in VTEC, it's still kicking in but it aint as aggressive as it use to be. Any suggestions on what it could be?
Old Apr 13, 2007 | 07:58 AM
itrSteez's Avatar
Default Re: Losing Power!!!! (sambo_666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sambo_666 &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, i'm losing power in VTEC, it's still kicking in but it aint as aggressive as it use to be. Any suggestions on what it could be?</TD></TR></TABLE>
you're used to it.
Old Apr 13, 2007 | 08:00 AM
sambo_666's Avatar
Default Re: Losing Power!!!! (itrSteez)
I thought that, but my mate took it it out who has an ITR. and he said it's lagging.
Old Apr 13, 2007 | 08:02 AM
LUCKY CHARMS's Avatar
check your oil & then check your header/exhaust has'nt been pinched,
you could elaberate a bit more with your cars backround & the circumstances it losing power under & you'll get better responces
Old Apr 13, 2007 | 08:05 AM
sambo_666's Avatar
The car has just been serviced, MOT'd, only owned it for about a month. it's a 1997 Honda Integra Type R JDM spec with 50,000miles on the clock.
Old Apr 13, 2007 | 08:15 AM
Dave-ROR's Avatar
My GS-R has the same problem, it's a bad cat in my case (I have a carsound cat that rattles quite loudly).. I think enough of the cat as disintegrated now cause the last two days it felt more normal.
Old Apr 13, 2007 | 08:32 AM
HSPxNick's Avatar
Default Re: (Dave-ROR)
fuel pressure, check/change your oil, check your recent mods, check injectors, leak down test...you can diagnosis alotta things, but those should be the easy ones
Rubixcu7
Mar 5, 2006 07:19 PM
RsxType-Stitch
16
Sep 7, 2005 07:52 PM
SmogTech01
Apr 5, 2005 11:44 PM
jansenrw
Apr 20, 2003 09:12 AM
