Condensation in back lights.
it happens as the seals dry out over the yeqars letting the water in....to fix the problem...A)remove the tailights ands get new gaskets or B0 remove tailights & use a small bead of silicone around old gasket to help seal...
also dry them out completely before reinstallin
Are you getting any water in your trunk?
It might not be the taillight gaskets at all, as was the case with my car. I had water coming in the top edge of the red lens. To figure that out, I filled my bathtub with water and then dunked the whole taillight assembly, with the red lens facing up. I saw tons of bubbles coming out the top edge of the red lens so I knew water was getting in there. I ran a bead of silicone along the top edge of the lens and haven't had any problems since.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 »</TD></TR><TR><TD CLASS="quote">it happens as the seals dry out over the yeqars letting the water in....to fix the problem...A)remove the tailights ands get new gaskets or B0 remove tailights & use a small bead of silicone around old gasket to help seal...
also dry them out completely before reinstallin</TD></TR></TABLE>
WERD, number B0(
) is easiest
WERD, number B0(
) is easiest
Oh believe me, I had plenty of water inside my taillight lenses, exactly like in those pics above. That's why I was asking if he was water in the trunk. The water came in through the top edges of the lenses, filled up the housing, and then spilled over into the trunk.
They are very easy to remove and I will guarantee that the issue is the inner gasket. I actually have a brand new one in the package that I never used. PM me if you want it for a good price!
