i think i'm missing 1500rpm to 2500rpm
Old Apr 13, 2007 | 01:33 AM
vtec25's Avatar
Default i think i'm missing 1500rpm to 2500rpm
i cant rev between those rpm's for nuthing. what could that be???
Old Apr 13, 2007 | 02:20 AM
bart2546's Avatar
Default Re: i think i'm missing 1500rpm to 2500rpm (vtec25)
What exactly do you mean...are you trying to say the car won't go up to that level? The car goes there and bogs or stalls? Does it go beyond those RPM's to higher ones...what's the exact situation.
Old Apr 13, 2007 | 07:52 AM
97Ej6mike's Avatar
Yea we need more of an exact diagnosis, Do you mean to say it wont rev past there? or does it rev slow (bogging out) thru those rpms?
Old Apr 13, 2007 | 08:31 AM
vtec25's Avatar
Default Re: (97Ej6mike)
if i press the gas pedal real slow it'l go up to 1500rpm and start to bounce like hitting rev limiter and keeps doing that till the gas pedal goes more down and then shoots up to 2500rpm. i cant whats so ever get the revs inbetween 1500 and 2500 and its annoying when trying to drive chilling cuz the car tends to jerk alot.
Old Apr 13, 2007 | 09:12 AM
hall97civic's Avatar
Default Re: (vtec25)
tps?
Old Apr 13, 2007 | 09:26 AM
97Ej6mike's Avatar
Yea, thats the TPS, unplug it, reset the ECU, and plug it back in. If that doesnt work, then you need to replace the sensor altogather.
Old Apr 13, 2007 | 09:28 AM
redline5th's Avatar
Sure sounds like a tps to me, is there any way to test it to be sure? Don't want to have to get a new one without knowing for sure.
Ah, mike you got your post in before mine
Old Apr 13, 2007 | 09:45 AM
Bejita's Avatar
You'll get a code 7 if it's the TPS.....I think it's 7.
Old Apr 13, 2007 | 07:32 PM
vtec25's Avatar
Default Re: (Bejita)
i'll try and reset the ecu 2moro. i dont have a code for the tps. i do have a code for iat and iac though
Old Apr 14, 2007 | 11:17 AM
97Ej6mike's Avatar
That could also be a clogged IACV, ive had issues with that before as well. Take it off, and clean it out.
Old Apr 14, 2007 | 04:25 PM
vtec25's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">That could also be a clogged IACV, ive had issues with that before as well. Take it off, and clean it out.</TD></TR></TABLE>
mine is clean. and i reseted the ecu and still got the problem.
Old Apr 14, 2007 | 05:31 PM
pythoner's Avatar
unplug it, it isn't nessisarily "nessisary" if it works fine, then its the sensor
Old Apr 15, 2007 | 09:38 AM
vtec25's Avatar
Default Re: (pythoner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pythoner &raquo;</TD></TR><TR><TD CLASS="quote">unplug it, it isn't nessisarily "nessisary" if it works fine, then its the sensor</TD></TR></TABLE>
if u mean the iac i just changed the clean one and still nuthing.
nipcup101
Aug 28, 2007 08:18 AM
vtec25
Jun 10, 2007 05:18 PM
DC5ftmfw
Sep 28, 2006 04:42 AM
PnX-R
Nov 12, 2002 10:51 AM
Sirvtec
Feb 10, 2002 03:21 PM
