motor is making a knock noise
Old Apr 12, 2007 | 10:09 PM
SickIntegraWon's Avatar
Default motor is making a knock noise
i have a b20/vtec, and it mkaes a knock noise only at certian rpms, normally at 3000-4500 rpms, could it be rod knock?? or could it be coming from the valves??, it doesnt do it at idle either..
Old Apr 13, 2007 | 12:44 PM
Default Re: motor is making a knock noise (SickIntegraWon)
bump
Old Apr 13, 2007 | 12:45 PM
unknown0001's Avatar
valves don't knock...they tick
more then likely you got a spun bearing = rod knock.
Listen to the engine while somebody is reving it for you. Try to hear the engine by the oil pan/bottom of the block and that will give you an idea where the knock is comming from.
Old Apr 13, 2007 | 12:51 PM
Default Re: motor is making a knock noise (Mr.RHTuner)
ok, but rod knock doesnt not happen at idle right? At a stand still it sounds normal. but yea it does sound like its coming from the bottom portion of the motor. Am i putting the motor at a danger if i drive it like this?
Old Apr 13, 2007 | 12:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SickIntegraWon &raquo;</TD></TR><TR><TD CLASS="quote">ok, but rod knock doesnt not happen at idle right? At a stand still it sounds normal. but yea it does sound like its coming from the bottom portion of the motor. Am i putting the motor at a danger if i drive it like this?
rod knock can happen at any RPM
-dont drive the car anymore as your just doing more and more damage
FeelTheBass
Feb 5, 2014 09:24 PM
RevrsOne
Other Make Vehicles
Aug 21, 2012 06:50 PM
[626]95-GSR
Aug 21, 2003 05:33 AM
[626]95-GSR
Aug 21, 2003 02:34 AM
