Bondo Question
Old Apr 12, 2007 | 09:06 PM
hmtcrxsir's Avatar
Default Bondo Question
I just bought a Denji Projectors for the 92-95 Civic similar to the one shown below. I do not like the third small city light in the corner of the projectors. I want to cover it up and spray the housing black. I was thinking Bondo to cover the hole up but Im afraid that the bondo might crack due to the heat and movement. Anyone suggestion any other material to cover up the third hole without worrying that it might crack overtime.
Old Apr 12, 2007 | 09:15 PM
umop-apisdn's Avatar
Bondo cannot support its self. It is not meant to fill in holes, only smooth out the surface it is applied to.
Old Apr 12, 2007 | 09:21 PM
hmtcrxsir's Avatar
Default Re: (umop-apisdn)
so what do you recommend to fill in holes?
Old Apr 12, 2007 | 09:23 PM
Crazy4Honda's Avatar
Default Re: (hmtcrxsir)
the stuff i recommend is called duraglass its bond to plastic really well, you can get it anywere
Old Apr 12, 2007 | 09:24 PM
hmtcrxsir's Avatar
Default Re: (Crazy4Honda)
it wont crack overtime?
Old Apr 12, 2007 | 11:18 PM
hmtcrxsir's Avatar
you think if i just fill the hole with fiberglass and bondo on top to make it smooth. you think it will crack overtime?
Old Apr 12, 2007 | 11:48 PM
VRD^don's Avatar
plastic welding..you can get the gun at harbo frieght for pretty cheaP!
Old Apr 13, 2007 | 02:05 AM
pythoner's Avatar
it WILL warp the light if you try to plastic weld...I have many hours of plastic welding under my belt
Old Apr 13, 2007 | 03:31 AM
92sipiece's Avatar
some stuff called 8115 made by 3m it is actually a panel bonding adhesive but it works well for repairing plastic and it is black. I use it all the time in a body shop
Old Apr 13, 2007 | 04:50 AM
kiddcarbuff's Avatar
Default Re: (92sipiece)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92sipiece &raquo;</TD></TR><TR><TD CLASS="quote">some stuff called 8115 made by 3m it is actually a panel bonding adhesive but it works well for repairing plastic and it is black. I use it all the time in a body shop</TD></TR></TABLE>YUP! OP try to find that
Old Apr 13, 2007 | 05:16 AM
95ProjectEJ1's Avatar
Default Re: Bondo Question (hmtcrxsir)
How visible is the spot for the city light w/ the light out? And didn't you see a picture of the lights you were going to purchase luminated before you bought them? Could have saved yourself some money
Old Apr 13, 2007 | 10:31 AM
dannis.'s Avatar
you could custom fab the denji projector to fit on a a type r style light and there you go.
Old Apr 13, 2007 | 10:33 AM
hmtcrxsir's Avatar
Default Re: Bondo Question (95ProjectEJ1)
yeah i think the third city light is fugly. i like the old school denji style. I got these for a good cheap price of $10. this is for my S2000 Retrofit so i needed a headlight that is clear. How about using Plastic Epoxy Glue, then fill the hole up and then use bondo to smooth it out. you think that will work without worrying it might crack overtime?
Old Apr 13, 2007 | 10:37 AM
dannis.'s Avatar
it sounds like it should hold but. i never done something like that on headlights before, if you plan on doing that you should tell me how it turns out. im curious now myself.
Old Apr 13, 2007 | 10:38 AM
hmtcrxsir's Avatar
Default Re: Bondo Question (DannisEG6)
yeah dont worry ill post tons of pix of my S2000 retrofit.
Old Apr 13, 2007 | 11:10 AM
If you got them for 10 bucks i would say to hell with them and try anything and everything... at worst you just lost 10 bucks. Keep us updated on the retrofit.
Old Apr 13, 2007 | 11:11 AM
hmtcrxsir's Avatar
i want to do it right the first time.
646EG
Mar 1, 2008 12:25 AM
hmtcrxsir
Apr 14, 2007 05:02 PM
hmtcrxsir
11
Apr 13, 2007 04:17 PM
hmtcrxsir
Apr 13, 2007 01:07 AM
hmtcrxsir
Apr 12, 2007 11:32 PM
