manual steering rack... bearing needs grease?
Old Apr 12, 2007 | 08:43 PM
beav's Avatar
Default manual steering rack... bearing needs grease?
anyone ever have this problem of leaving the car standing for a week or two and then have the steering rack squeaking? i dont know if this is the issue but its what ive found in searches. some people say its a bearing and sme say its a bushing that needs to be greased.
can anyone verify which it is and the complexity of the job?
i cant hear the noise from the outside of the car, but from the inside, its clearly heard when turning the wheel about half a turn in either direction.
i have no power steering.
Old Apr 13, 2007 | 05:25 AM
beav's Avatar
Default Re: manual steering rack... bearing needs grease? (beav)
bummpp.............
Old Apr 13, 2007 | 05:44 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
steering rack itself is nto serviceable. besides, there is a ton of grease on it. since you hear it ont he inside only, my guess is it is squeaking in the column or coupler joint. check those first.
Old Apr 13, 2007 | 05:56 AM
beav's Avatar
Default Re: manual steering rack... bearing needs grease? (Rodney)
well, i just stuck my head under the steering wheel and removed the plastic shield to see the metal parts. but when i turn the wheel, it still seems like the sound is coming from past the firewall
Old Apr 13, 2007 | 07:32 AM
Bejita's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney &raquo;</TD></TR><TR><TD CLASS="quote">steering rack itself is nto serviceable. besides, there is a ton of grease on it. since you hear it ont he inside only, my guess is it is squeaking in the column or coupler joint. check those first.</TD></TR></TABLE>
This is bullshit.....You can take out the entire rack and rebuild it...You can buy a kit from advanced for 75 bux..It is not "packed" with grease either. There is a little to help with the smoothness. Probably the rack end bushing. Start here http://www.hondaautomotivepart...R+BOX
Old Apr 13, 2007 | 07:33 AM
Bejita's Avatar
It could also just be the boots.
Old Apr 13, 2007 | 07:54 AM
Rodney's Avatar
Default Re: manual steering rack... bearing needs grease? (Bejita)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita &raquo;</TD></TR><TR><TD CLASS="quote">This is bullshit.....You can take out the entire rack and rebuild it...You can buy a kit from advanced for 75 bux..It is not "packed" with grease either. There is a little to help with the smoothness. Probably the rack end bushing. Start here http://www.hondaautomotivepart...R+BOX</TD></TR></TABLE>
wtf is your problem? why so hostile? i never said you can't rebuild it. it is not serviceable, as in you do not need to grease it routinely. anyway, the i doubt the squeak is coming from the internal gearset. before telling him to rebuild his rack, he should narrow down the problem.
Old Apr 13, 2007 | 07:57 AM
Bejita's Avatar
I apologize.....I misread your post and took it the wrong way. You are 100% correct.
Old Apr 13, 2007 | 07:58 AM
Rodney's Avatar
Default Re: (Bejita)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita &raquo;</TD></TR><TR><TD CLASS="quote">I apologize.....I misread your post and took it the wrong way. You are 100% correct.</TD></TR></TABLE>
Old Apr 13, 2007 | 03:52 PM
beav's Avatar
haha, nice to see we're all getting along
yeah i dont think its the gear set either, like i said, i think its the bearing, but i wasnt sure if its a bearing or a bushing that im looking for that needs to be greased
Old Dec 4, 2008 | 02:03 PM
jeepman173's Avatar
Default part #
Do you have a p/n for this rebuild kit? I called both advanced and autozone and neither have a rebuild kit and only have a seal kit. Is this the kit that you are referring too? Is this all that can be serviced inside the rack?
noahs_ark
Honda Civic (2006 - 2015)
Sep 12, 2016 05:25 PM
Egpower88
Apr 26, 2009 10:22 AM
Osek206
13
Nov 7, 2005 02:13 PM
