What tire pressure for AutoX using Toyo RA-1?
Old May 27, 2002 | 09:06 PM
typer0853's Avatar
Default What tire pressure for AutoX using Toyo RA-1?
Hey Guys,
What tire pressure would you recommend for Toyo RA-1 used for AutoX?
Tire size is 205/50/R15 mounted on Rota Slipstreams. Assume 25 degrees C (77 degree F) ambient temp. Thanks in advance
Old May 27, 2002 | 09:19 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default Re: What tire pressure for AutoX using Toyo RA-1? (typer0853)
I'm not sure I would try about 39F/42R, but for drag racing someone claimed 16psi up front on a stock R with just a removed power steering belt got them a couple 13.9 on those same tires. You be the judge!
Old May 27, 2002 | 10:15 PM
Bob#455's Avatar
Default Re: What tire pressure for AutoX using Toyo RA-1? (01PYTypeR#1140)
16 psi for autox = Try 40/42, do your first run, then adjust as necessary by judging the amount of rollover.
Jaydeep
13
Jul 25, 2010 09:27 PM
ReDHaTcHyGuy
Nov 3, 2005 11:27 AM
Twigster311
Aug 10, 2003 05:31 PM
adrian1281
Jun 28, 2003 08:39 AM
flip1199
Jan 13, 2003 02:27 AM
