motor help for noob
Old Apr 12, 2007 | 07:19 PM
adamintegra06's Avatar
Default motor help for noob
i want to build a motor with 11:1 compression forged pistons and mild cams... do i did bigger injectors and if so what size?... and do i did new clutch if so what kind?
thanks for any help
Old Apr 12, 2007 | 08:36 PM
tdark1582's Avatar
Default Re: motor help for noob (adamintegra06)
u basically want a type r motor and u wont have 2 get bigger injectors or a new clutch unless u need a clutch. it would help to get some 310 rc injectors and a stage 2 clutch, adj cam gears and a good tune and u will be ok
Old Apr 12, 2007 | 08:42 PM
unknown0001's Avatar
Default Re: motor help for noob (tdark1582)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdark1582 &raquo;</TD></TR><TR><TD CLASS="quote">u basically want a type r motor and u wont have 2 get bigger injectors or a new clutch unless u need a clutch. it would help to get some 310 rc injectors and a stage 2 clutch, adj cam gears and a good tune and u will be ok</TD></TR></TABLE>
I think he's talking about building a motor NOT buying an ITR swap
adam---do you want to build a LS engine allmotor?
Old Apr 13, 2007 | 05:41 PM
yea i wanna build my ls motor with 11:1 pistons and mild cams what esle do i need? and can i run on pump gas with that compression? maybe 10.5:1 pistons
thanks
adam
Old Apr 13, 2007 | 07:39 PM
doood's Avatar
been there done that
pump gas is fine with 11:1 compression. you just need a good tune.
injector size is dictated by hp levels. stock injectors are good for 180-190whp but at a pretty high duty cycle. 310cc's would be more than enough if you feel like upgrading.
Old Apr 14, 2007 | 02:30 PM
is tuning required? wnt i need a stage clutch and cam gears along with the bigger injectors? and if tuning is reguired can i send my ecu off for the tuning or do i have to take my car in for the tuning? if i went with 10.1:1 pistons and mild cams would tuning be required?
Old Apr 14, 2007 | 02:34 PM
doood's Avatar
tuning is always required imo when you start messing with things like compression and cams if you want the most out of them and want things to run safely and reliably. the best way to do this is the get a socketed and chipped ecu tuned on a dyno.
Old Apr 14, 2007 | 02:43 PM
Default Re: motor help for noob (doood)
so could i like send in my ecu and included the specs of the pistons and cams and size injectors and type of clutch and the tuning shop socketed it and chip it based on the specs i send them?
Old Apr 14, 2007 | 03:00 PM
doood's Avatar
you can do that and get a basemap burned but that should only be used to get you started so you can get the car to a dyno for fine tuning
Old Apr 14, 2007 | 03:02 PM
anybody you would suggest?
Old Apr 14, 2007 | 03:11 PM
doood's Avatar
http://www.evans-tuning.com if you're close to them. even if you're not, he's one of the best tuners in the country and worth the drive.
Old Apr 14, 2007 | 03:34 PM
can i send my ecu into to them for a chip?
Jrkej1
Texas -OK -LA (Sales)
Nov 8, 2012 08:28 PM
Jrkej1
Nov 7, 2012 07:06 PM
LSVtechnologytur...
Aug 17, 2005 07:18 PM
ek9800
Aug 2, 2005 07:09 PM
